Thread: Which catalytic converter to get?
Results 1 to 4 of 4
  1. #1 Which catalytic converter to get?
    Jan 2014
    Algonquin, IL
    I need to put a catalytic converter back on my 05 compg for emissions testing. I took my old one off when I had the SD headers put on. I'd imagine I need a 3" cat now...can anyone show me which cat they have used? Thanks!
    Would this work? http://www.ebay.com/itm/Magnaflow-94...-/301381750797
  2. #2 Re: Which catalytic converter to get?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    if its just to pass emissions i would get a stock ish unit and some flanges and weld it up so that you can put it in just to test and remove and replace with a straight pipe after the testing. most hi flow cats arent very good if you have to get sniffed.
  3. #3 Re: Which catalytic converter to get?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    I got his one and had it welded into place when i installed my SD headers in August. Works. And just passed inspection here in NC.
    Hi-flow is the way to go!
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Which catalytic converter to get?
    Quote Originally Posted by chrsmi1 View Post
    That's wht I'm using.. I have the cat codes disabled though and also don't have to worry about emissions here..
    04 Comp G.
  1. catalytic converter
    By musicman126 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2013, 12:09 PM
  2. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  3. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
