Thread: Minor cruise control problem only when it's cold
Results 1 to 6 of 6
binnes Minor cruise control problem... 12-02-2014, 07:36 AM
BillBoost37 Re: Minor cruise control... 12-02-2014, 08:05 AM
stocker Re: Minor cruise control... 12-02-2014, 02:24 PM
BillBoost37 Re: Minor cruise control... 12-02-2014, 02:27 PM
stocker Re: Minor cruise control... 12-02-2014, 05:47 PM
binnes Re: Minor cruise control... 12-03-2014, 11:30 AM
  1. #1 Minor cruise control problem only when it's cold
    Dec 2014
    Hi everyone, newbie here. I've had a 2007 Grand Prix for about 20 months now and entering my second winter with it. I've got a weird problem where if the temperature is cold (<25 degrees F or so) when I hit the increase switch on the cruise control, it just shuts off. The set button still works no problem, and the increase button works perfectly during the warm parts of the year. Anyone know what this might be? My first thought would be a wiring issue but why only when it's cold? Thanks in advance.
  2. #2 Re: Minor cruise control problem only when it's cold
    I've seen this type of behavior myself. There's a spot in the switch that doesn't read the right thing and it's essentially turning your cruise off. Likely you need a multifunction switch to be replaced to fix the issue.
  3. #3 Re: Minor cruise control problem only when it's cold
    GTP Level Member
    Aug 2012
    st louis park, MN
    I think my car did this when I first bought it. It went away and I forgot about it. You could replace the whole multi function switch but that is kind of expensive.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  4. #4 Re: Minor cruise control problem only when it's cold
    Quote Originally Posted by stocker View Post
    Rockauto has it listed as Delco for either $19 or $21 depending on fog lamps or not.
  5. #5 Re: Minor cruise control problem only when it's cold
    GTP Level Member
    Aug 2012
    st louis park, MN
    Boy, I got screwed by NAPA then. That is a good deal!
  6. #6 Re: Minor cruise control problem only when it's cold
    Dec 2014
    Thanks for the input guys! I'll check it out.
  1. Strange Speedometer / Cruise Control Problem
    By jimhollis in forum General Tech Discussion
    Last Post: 03-27-2014, 10:19 AM
  2. cruise control problem- how to diagnose?
    By genki in forum General Tech Discussion
    Last Post: 08-30-2013, 08:07 AM
  3. Cruise control problem
    By Dozerman51 in forum General Tech Discussion
    Last Post: 08-29-2013, 09:30 PM
  4. Cruise Control problem.
    By jordyfallacy in forum General Tech Discussion
    Last Post: 03-08-2010, 11:32 PM
