Thread: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind engine
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 160
  1. #1 Pics..Help me find cause of oil leak.leaking on side of passenger tire behind engine
    Dec 2013
    WORK
    Ok my oil drained out within 2 weeks. refilled today and noticed it's leaking right to the side behind the passeneger tire. Dripping out and I can see on the bar and over the cc joints
    You guys did an amazing job helping me with the p0102 code so I don't doubt at all that you guys won't help me now..
    I'm sure somebody had this leak before.
    It's like kind of behind the engine. if your looking over the alternator straight down I can see the leak directly below on the ground
  2. #2 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Oil pressure sensor is on the back of the engine in that area.
    Your sure it's oil? Power steering pump is right below the alternator
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Op should have linked to other thread about loosing oil.
    But indy is correct buy a new oil pressure sensor and replace it.
    Sent from A Galaxy Far Far Away........
  4. #4 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    GTP Level Member
    Aug 2012
    st louis park, MN
    Is your filter tight?
    I'm thinking a picture would be helpful. Can't you trace the oil up to where it is leaking? If its too grimy to see where it is coming from, clean the area with engine cleaner and then you might actually be able to see where the leak is springing from...?
    Good Luck.
  5. #5 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Enfield, CT
    yea it would be a good idea to post pics of the leak. so far, it sounds like the oil pressure sensor. You didn't double gasket the oil filter did you?
  6. #6 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Dec 2013
    WORK
    Quote Originally Posted by indygrandprix View Post
    It's oil. I was losing oil before
    Quote Originally Posted by Slick2500 View Post
    Would the oil pressure sensor cause it to lose oil?
    Quote Originally Posted by stocker View Post
    Good Luck.
    Thanks oil filter is on tight. I was losing oil before I changed the oil and filter. I will post pics soon.
    Quote Originally Posted by highoctaneracing View Post
    It's not leaking from there. oil filter area is clean
  7. #7 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Enfield, CT
    If the sensor is leaking oil then yes. replace sensor. Also the sooner you post pics of the leak, the sooner you'll get help
  8. #8 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Or you could pull a scotty and just plug the hole lol, all that sensor does is conveniently come on when your engine is "done".
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Antioch, IL
    I plugged mine as well, and by the looks of it I did it just in time, oil isnt supposed to be where it was.
    2009 Challenger SRT8
    Expert at being gay.
  10. #10 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Dec 2013
    WORK
    Quote Originally Posted by ITHURTZ View Post
    Where is the senser?
    Pics uploading now
  11. #11 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Dec 2013
    WORK
    Pics uploaded guys inmy orignial post up top
  12. #12 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Antioch, IL
    Quote Originally Posted by Prixness View Post
    Pics uploading now
    above the oil filter, but on the back of the engine, before the axle. Horizontal sensor with the plug on the end of it, not hard to miss its really the only plug right there.
  13. #13 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Antioch, IL
    oil sensor by smetters20, on Flickr
  14. #14 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Enfield, CT
    pics are quite sh!tty but that oil is in the right spot for an oil pressure sensor leak
  15. #15 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Enfield, CT
    Perfect pic lol
  16. #16 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Jan 2012
    Indianapolis
    If it ends up not being the oil pressure sensor then the next likely culprit is your front crank seal....just pray it's not that.
  17. #17 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    When my front seal went out it didn't leak that bad.
  18. #18 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2013
    WORK
    Plug with what?
  19. #19 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Enfield, CT
    Re-read the post
  20. #20 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2013
    WORK
    Re-read the post
    you guys are sayingplug it and I re-read. Do i take it off then plug it with something or is it something there for me to plug it in?? Im not getting it
  1. Wire hanging from under car near Passenger Side tire
    By gamefreak in forum Brakes/Suspension/Chassis
    Last Post: 07-10-2013, 03:35 PM
  2. Clunking from passenger side tire area
    By DJE in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 07:08 PM
  3. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  4. Passenger Side Leak
    By Toney Halbert in forum General Grand Prix Discussion
    Last Post: 03-13-2012, 09:13 AM
  5. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
