Thread: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind engine
Results 1 to 20 of 160
  1. #1 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Enfield, CT
    yea it would be a good idea to post pics of the leak. so far, it sounds like the oil pressure sensor. You didn't double gasket the oil filter did you?
  2. #2 Re: Help me find cause of oil leak..leaking to the side of passenger tire behind engi
    Dec 2013
    WORK
    Quote Originally Posted by indygrandprix View Post
    Oil pressure sensor is on the back of the engine in that area.
    Your sure it's oil? Power steering pump is right below the alternator
    It's oil. I was losing oil before
    Quote Originally Posted by Slick2500 View Post
    Op should have linked to other thread about loosing oil.
    But indy is correct buy a new oil pressure sensor and replace it.
    Sent from A Galaxy Far Far Away........
    Would the oil pressure sensor cause it to lose oil?
    Quote Originally Posted by stocker View Post
    Is your filter tight?
    I'm thinking a picture would be helpful. Can't you trace the oil up to where it is leaking? If its too grimy to see where it is coming from, clean the area with engine cleaner and then you might actually be able to see where the leak is springing from...?
    Good Luck.
    Thanks oil filter is on tight. I was losing oil before I changed the oil and filter. I will post pics soon.
    Quote Originally Posted by highoctaneracing View Post
    It's not leaking from there. oil filter area is clean
  1. Wire hanging from under car near Passenger Side tire
    By gamefreak in forum Brakes/Suspension/Chassis
    Last Post: 07-10-2013, 03:35 PM
  2. Clunking from passenger side tire area
    By DJE in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 07:08 PM
  3. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  4. Passenger Side Leak
    By Toney Halbert in forum General Grand Prix Discussion
    Last Post: 03-13-2012, 09:13 AM
  5. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
