Thread: Codes
Results 1 to 10 of 10
  1. #1 Codes
    May 2012
    Canada , Sarnia
    Today and got got a code reader and hooked it up to my 04 Grand Prix and 2 codes showed up
    - P0420 - Catalyst System Efficiency Below Threshold Bank 1
    - P0446 - Evaporative Emission System Vent Control Circuit
  2. #2 Re: Codes
    http://www.p0420.com/ cat code you got a hi flow cat? or no cat?
    http://www.obd-codes.com/p0446 evap stuff is bad.
  3. #3 Re: Codes
    May 2012
    Canada , Sarnia
    Still got the stock cat on
  4. #4 Re: Codes
    how many miles? it could be bad or going bad.
    the car feel dog ish at all? aka lacking power?
  5. #5 Re: Codes
    May 2012
    Canada , Sarnia
    Has 256,000 and no feels like its running fine I notice when it gets cold tho when I start it up in the morning the rpms bounce don't stay steady
  6. #6 Re: Codes
    could be a vac leak on the engine, could be the cause of the evap code too.
    spray some carb cleaner at the vac lines at idle, if the idle jumps up, you found your leak area.
  7. #7 Re: Codes
    May 2012
    Canada , Sarnia
    Where are the vac lines
  8. #8 Re: Codes
    the thin black plastic tubes that run around the engine and to a few sensors and the throttle body.
  9. #9 Re: Codes
    May 2012
    Canada , Sarnia
    ok does it have to be carb cleaner I got throttlebody cleaner and will do that tomorrow after work
  10. #10 Re: Codes
    TB cleaner will work too.
  1. a few codes i need help with!
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2013, 07:53 AM
  2. 7 codes.....yay....not... HELP!
    By deadsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2013, 06:35 AM
  3. got some codes need help
    Last Post: 10-22-2012, 06:20 AM
  4. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  5. Have some codes need help
    By pDuB257 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 03:25 PM
