and ive never heard of anyone having to change the coolant bottle to install a intake![]()
did a pressure test the radiator is cracked :/. the coolant bottle on the 97 gtp is right behind the headlight on the drivers side, unlike the other wbodies where its on the passenger side by the alternator. It blocks the intake from using the opening behind the headlight to pull in air. most of the aftermarket CAI pull from the headlight opening (so ive seen) unless you go fender. im just going to put a stock newer year intake on it gut it and stick a cone inside.
