Thread: Leaky coolant bottle?
Results 1 to 13 of 13
  1. #1 Re: Leaky coolant bottle?
    If this is a 3800, look at the coolant elbows. Also make sure the rubber hose from overflow to radiator isn't rubbed through by the belt.
  2. #2 Re: Leaky coolant bottle?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Thanks, i went ahead and ordered a coolant bottle since this is a 97 and i need to change to a new style bottle for the intake anyway.
    If i dont see any leaks, i might just go ahead and order the Radiator anyway.
  3. #3 Re: Leaky coolant bottle?
    and ive never heard of anyone having to change the coolant bottle to install a intake
  4. #4 Re: Leaky coolant bottle?
    Sep 2014
    Richmond Virginia
    did a pressure test the radiator is cracked :/. the coolant bottle on the 97 gtp is right behind the headlight on the drivers side, unlike the other wbodies where its on the passenger side by the alternator. It blocks the intake from using the opening behind the headlight to pull in air. most of the aftermarket CAI pull from the headlight opening (so ive seen) unless you go fender. im just going to put a stock newer year intake on it gut it and stick a cone inside.
  5. #5 Re: Leaky coolant bottle?
    Quote Originally Posted by 04lss View Post
    i got a 98, same bottle all hidden in the rad support. slap a 30 dollar home made cone filter on there and call that done. theres no real gains from any intake your gonna buy.
    i got a spare 01 box myself id sell. shipping costs cant be fun tho.
  6. #6 Re: Leaky coolant bottle?
    Enfield, CT
    try to see if it will fit in a USPS 2-day medium flat rate box since that box is only $12.95
  1. Will a coolant overflow bottle from a 99 fit onto a 97?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2012, 02:26 PM
