Thread: Coolant/Water Flow Direction
Results 1 to 16 of 16
  1. #1 Coolant/Water Flow Direction
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    Here is a question that I can't get a straight answer for, from anybody. It might sound like a silly question, but you will be surprised by how many people that don't get the answer correct.
    What direction does the coolant/water flow from the engine into the radiator?
    Top Hose or Bottom hose.
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  2. #2 Re: Coolant/Water Flow Direction
    SE Level Member jimzssei's Avatar
    Sep 2014
    The top ... Are you trying to trick us?
  3. #3 Re: Coolant/Water Flow Direction
    May 2013
    Quote Originally Posted by jimzssei View Post
    Maybe....lol
  4. #4 Re: Coolant/Water Flow Direction
    water flows out from the t stat to the upper rad hose. the lower hose is cooler water going back into the engine.
  5. #5 Re: Coolant/Water Flow Direction
    hangover park IL
    Quote Originally Posted by Flip97GTP View Post
    on a 3800 and most non mixer style cooling systems the upper hose is hot water discharge from T stat to radiator, lower is cold water supply to engine.
    this is not always the case with newer mixer style thermostat engines, in this case it could be either way depending on packaging constraints
    ~James~ Psychotic Gearhead
  6. #6 Re: Coolant/Water Flow Direction
    May 2013
    Quote Originally Posted by Turbocharged400sbc View Post
    Yes, that's what I thought, but there is a few people I know that want to debate with me about this. They say I'm wrong and that it's the other way around.
    I googled it and I got both answers for this question!
  7. #7 Re: Coolant/Water Flow Direction
    Tell them to pull a hose and find out
  8. #8 Re: Coolant/Water Flow Direction
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Even better... Have them put their face up to the top hose if they are so sure of themselves.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  9. #9 Re: Coolant/Water Flow Direction
    May 2013
    Quote Originally Posted by Frosty View Post
    Exactly......not a bad idea, Lmao! They won't do it though.
  10. #10 Re: Coolant/Water Flow Direction
    May 2013
    Yea, that is exactly what I'm going to do! This weekend.....Lol this is going to be good.
  11. #11 Re: Coolant/Water Flow Direction
    how i flush my coolant. this does work, many here have done it this way.
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
    done.
  12. #12 Re: Coolant/Water Flow Direction
    May 2013
    done.
    This is a good flushing system, Scotty!
    About a year a ago I bought the flushing and that seems to work good, also!
    Thanks for the well detailed post.
  13. #13 Re: Coolant/Water Flow Direction
    hangover park IL
    tell em to change the thermostat and "upper" hose on a quad4
  14. #14 Re: Coolant/Water Flow Direction
    GTP Level Member
    Oct 2014
    The confusion may come from the lower hose heating up first from latent engine heat before the t stat opens.
    Sent from my iPad using Tapatalk
  15. #15 Re: Coolant/Water Flow Direction
    GTP Level Member
    Aug 2012
    st louis park, MN
    I would have gotten this wrong. Good to know.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  16. #16 Re: Coolant/Water Flow Direction
    May 2013
    Yes it is
  1. 2000 GTP overheating and no coolant flow
    By ss10409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2014, 12:41 AM
  2. Coolant/Water Leak? Please help!
    By bm2112 in forum General Tech Discussion
    Last Post: 05-17-2012, 05:09 PM
  3. coolant flow
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2010, 10:54 PM
  4. coolant to water? help quick.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-27-2010, 10:12 PM
  5. Throttle Body Spacer/Coolant Flow
    By TeeWX in forum General Tech Discussion
    Last Post: 03-26-2010, 12:38 PM
