Thread: coolant to water? help quick.
Results 1 to 5 of 5
  1. #1 coolant to water? help quick.
    Joliet, IL
    i flushed my green out after my dexcool swap just to make sure what ever dexcool mixed in w/ the green was also out.....now should i do 50/50 or is using more green to water better or vise versa? ive been pre diluting it my self in the bottle by pouring half into another bottle and filling them up with water? also i cant get my heater core to open because its so damn hott out that my car wont blow heat with the hvac on 90* it still blows ac lol is there a way to open it otherwise? lemme know what i should do im gonna fill tonight....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: coolant to water? help quick.
    Apr 2009
    stockton ca
    turn to full heat max and turn ac off dont use auto control
    as for the 50/50 mix that should be fine water is better at disapating heat only time id go more concentrated on the coolant is winter time if your winters are harsh
  3. #3 Re: coolant to water? help quick.
    Joliet, IL
    Quote Originally Posted by TorqueAutoMotiv View Post
    when i put the digital hvac on 90 its still cold air.....
    00 Silvermist GTP
  4. #4 Re: coolant to water? help quick.
    Apr 2009
    stockton ca
    then there something wrong there is the car up to temp?
  5. #5 Re: coolant to water? help quick.
    Joliet, IL
    it was the hose lol the water was so cold it was getting to the HC and the flush kit was making the heater core cold there for no cold air lol cut off the hose (the core was still open)....thanks for the help, this was the 3rd flush to ensure i was all green and shes running like a champ....i had an ass load of air in the system when i bled it however.
    00 Silvermist GTP
  1. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  2. Coolant spray/leak. Quick fix just 1 question
    By VejGTP in forum General Tech Discussion
    Last Post: 12-26-2009, 11:10 PM
  3. Help quick! Coolant bleed?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2009, 08:14 PM
  4. Quick question (water pump)
    By cgator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 08:03 AM
  5. Quick question (water pump)
    By cgator in forum General Tech Discussion
    Last Post: 09-21-2008, 10:13 PM
