2000 Grand Prix GT
215,000 miles
The cable in the regulator was all frayed about exactly a year ago and I replaced the regulator but kept the same motor and everything worked until about 3 days ago when the window completely stopped going up and down. I took the regulator & motor out to find out the cable was frayed again and all caught inside the spinning plastic hub that it winds itself around near the motor gear.
Thankfully RA warrantied the part and sent out a new one, I just put in the new regulator (still the same motor) and it goes up and down beautifully for about 10-15 seconds then it craps out, it just dies and doesn't even struggle to move. If I wait about 30-60 seconds I can get it to move again but only for an even shorter amount of time before it craps out.
My question is should I replace the motor? Or should I replace the switches? Or both?
Are there any other tests I should be doing to further narrow down the problem? Perhaps my real problem (be it the motor or the switches) is what caused the cable to fray the first two times?...
Thanks in advance!
