Ok,
So my budget is extremely limited and I can't really replace a bunch of things to try to figure out what a root cause is. So here are the issues I am currently seeing with "big red"
PS steering fluid just dumping from tank area - I know the pump is the cause and place to replace. But recently got a loud screaming noise at idle in gear and also around 1800rpm, its not your typical PS whine but more of a howling noise, just wondering if that is a typical noise of dying pulley bearings. Its hard to pinpoint where it is coming from because the RPMs in neutral cause the noise to dissappear.
Transmission hating 4th gear. Just slips like crazy and if going up an incline at about 50mph and give it about 3/4 throttle will just switch from 4 to 3 and back over and over really fast. I guess i'm going to lose 4th soon, or my torque converter is dying, or my 4th clutch pack is dead. Still need to do a pan drop to see how much of my trans is in the pan.
Loud clunk on accel and deccel in mid to bad of car, not really sure what this is, sounds like something is loose on the frame and its sliding when torque is applied to front from breaking or back from accel.
Any ideas on what/how to check to help save me some uneeded spending
