Thread: Couple of questions on my new brain tumor (98 GTP)
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Couple of questions on my new brain tumor (98 GTP)
    Oct 2014
    United States
    Thanks again Scotty!!
  2. #22 Re: Couple of questions on my new brain tumor (98 GTP)
    Oct 2014
    United States
    Here is squealing
    http://youtu.be/m3FiuD5EIGM
    Couldn't add URL normally
  3. #23 Re: Couple of questions on my new brain tumor (98 GTP)
    its private.
  4. #24 Re: Couple of questions on my new brain tumor (98 GTP)
    Oct 2014
    United States
    Grrr
  5. #25 Re: Couple of questions on my new brain tumor (98 GTP)
    hard to say, you have power steering at all? if not its the pump, if your touching the brakes it could be them.
  6. #26 Re: Couple of questions on my new brain tumor (98 GTP)
    Oct 2014
    United States
    Def not brakes. Happens at a standstill in gear, in think PS too, but I still have it
  7. #27 Re: Couple of questions on my new brain tumor (98 GTP)
    get the belts pulled off one by one, check back.
  8. #28 Re: Couple of questions on my new brain tumor (98 GTP)
    Oct 2014
    United States
    Will do, have 3 hour drive home first.... Blah
  9. #29 Re: Couple of questions on my new brain tumor (98 GTP)
    maybe pull over at a parts store and investigate it then. if a pulley lets go, well sometimes your buying more than just a new pulley, add a belt, crank sensor maybe if the belt wraps is self around the crank, and so on.
  10. #30 Re: Couple of questions on my new brain tumor (98 GTP)
    Oct 2014
    United States
    Question, are the internals of the water pump lubricated via the coolant?
  11. #31 Re: Couple of questions on my new brain tumor (98 GTP)
    dont think so, theres a bearing pressed in the nose where the shaft exits.
  1. Got a couple questions i need help with
    By Dvst8r in forum General Grand Prix Discussion
    Last Post: 02-16-2014, 06:47 PM
  2. New here, couple questions.
    By osiris94ej in forum Introductions/Noob Questions
    Last Post: 11-16-2012, 10:07 AM
  3. Couple of questions....
    By Koniig in forum 5.3L V8 (LS4)
    Last Post: 05-23-2011, 02:45 PM
  4. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  5. A couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 04-12-2009, 07:56 PM
