Thread: Driver Airbag removal, broken wires
Results 1 to 8 of 8
  1. #1 Re: Driver Airbag removal, broken wires
    you broke the clock spring. you take the air bag off, then the wheel and then a ring clip and its the round thing under the snap ring, the wire runs down the column to under the dash and gets plugged in under there with the ignition harness. its bolted with a 8 mm bolt iirc. if you have radio buttons on your wheel that wires plug is by the obd2 port.
  2. #2 Re: Driver Airbag removal, broken wires
    Oct 2014
    Virginia
    Oh ok. I don't have radio controls. Are there any pics of this by chance for this model? I wanna know what I'm in for before I start on it. Thanks
  1. Broken Coil Spring. Advice on removal
    By TheInterloper in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2013, 08:34 AM
  2. Replies: 14
    Last Post: 03-28-2012, 04:44 PM
  3. Airbag removal and installation
    By mach158 in forum General Tech Discussion
    Last Post: 06-05-2011, 05:07 PM
