Thread: Best way to remove sunroof
Results 1 to 10 of 10
  1. #1 Best way to remove sunroof
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    So the GTP I got, needs the sunroof replaced, i got one from the junkyard, but i somewhat ruined the head liner in the process.
    What is the best way/process to get the headliner off? I know the door handles and the sun visors have to be removed but after that im not sure.
  2. #2 Re: Best way to remove sunroof
    The A, B and C pillars have to be removed, then the overhead console or switch for it and sunvisors. After that it should have a little velcro holding it up.
  3. #3 Re: Best way to remove sunroof
    GT Level Member Tea Time's Avatar
    New Brunswick
    all the 'holy sh*t' handles need to be removed and also one plastic push pin needs pryed out at the very rear of the headliner in the and also the plastic trim around the sunroof hole itself. just work that out carefully. no bolts or clips on that trim.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  4. #4 Re: Best way to remove sunroof
    Yeah.. uh.. I forgot those
    I think GP visors have screws holding them up. If it's just an odd slot, LMK. I have the procedure for that dumb fargin Regal visor slot abortion
  5. #5 Re: Best way to remove sunroof
    New Brunswick
    yep, 3 Phillips screws on the visor itself and just one Phillip screw for the inner piece that braces the visor.
    also, since you're all the way in there, this is a good time to clean out all 4 sunroof drain tubes. i used the air compressorto send a shot of air through then the garden hose. all kinds of nasty crap came out...lol
    '97 GTP - Project
  6. #6 Re: Best way to remove sunroof
    Sep 2014
    Richmond Virginia
    Whats the best way to remove the Pillars in the rear? I think the front ones just clip in right?
  7. #7 Re: Best way to remove sunroof
    New Brunswick
    Front and rears just clip in, different style of clips from front to back but you'll see when they pop off.
    '97 GTP - Project
  8. #8 Re: Best way to remove sunroof
    Nov 2011
    NY
    Have a look here...
    http://www.grandprixforums.net/threa...Sunroof+repair
    Pretty much everything Sunroof but you were afraid to ask about! Lol
  9. #9 Re: Best way to remove sunroof
    I live here. DirtDog's Avatar
    Jun 2012
    I can almost post more info if need be. I've had my sunroof removed twice. It's not hard but easier to do with seats out completely
  10. #10 Re: Best way to remove sunroof
    Sep 2014
    Richmond Virginia
    I replaced it this weekend the new one works! However I didn't get the sunroof trim with the new one. It was plastic on the junkyard car I hot it from. In my car it was like vinyl and glued to the sunroof. Is it possible for me to use the plastic trim on my car?
  1. Sunroof
    By 94grandprix in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 01:06 PM
  2. sunroof
    By gordster1122 in forum General Tech Discussion
    Last Post: 12-13-2012, 02:13 PM
  3. How do I remove sunroof switch trim
    By SnowDrift in forum General Tech Discussion
    Last Post: 05-19-2011, 06:55 AM
  4. Sunroof
    By zildjian102 in forum Visual/Body Modifications
    Last Post: 10-23-2010, 06:26 AM
  5. HELP! Sunroof
    By GTPluv in forum General Tech Discussion
    Last Post: 10-19-2008, 07:04 PM
