Thread: Lower intake manifold question?
Results 1 to 11 of 11
  1. #1 Lower intake manifold question?
    Sep 2014
    United States
    Why would oil pool up inside the channel were the inside bolts are? It is like this on both sides. After I replace the upper and lower intake gaskets. Will this fix the issue or will I need to do something else?
  2. #2 Re: Lower intake manifold question?
    bad pcv could do that, or it seeped up from the lim bolts
    make sure you use thread sealant on the lim bolts when they go back in.
  3. #3 Re: Lower intake manifold question?
    Sep 2014
    United States
    Ok I will make sure to add sealant to the bolts before putting them back in. Thanks!
  4. #4 Re: Lower intake manifold question?
    hangover park IL
    its normal condensation/accumulation over time from the pcv system.
    pull it apart at 10k and youll see the puddle, it just wont be as full or dirty as a 75k+ lim
    ~James~ Psychotic Gearhead
  5. #5 Re: Lower intake manifold question?
    Enfield, CT
    Quote Originally Posted by durell81 View Post
    I remember these times lol. If you have access to a quality sandblaster, sandblast it and jet wash it or rinse it out to make sure you get all the glass out
  6. #6 Re: Lower intake manifold question?
    hangover park IL
    Quote Originally Posted by HighOctaneRacing View Post
    never sandblast it, the carbon should be soaked in cheap old kerosene and scrubbed.
    too much chance for sand to get stuck inside a pcv passage and kerosene is like 4$ a gallon and a rubbermaid tote is like 10$ steal yer old lady's toothbrush, and an old water bottle with a few pinholes in the side for rinsing under pressure/stream.
    100 pack of razor blades and change em often as they get nicked
  7. #7 Re: Lower intake manifold question?
    Jul 2012
    Chicago
    No point in scrubbing it and making it pristine if it's gonna happen again.
    -Carl
  8. #8 Re: Lower intake manifold question?
    Agreed.. it's totally normal for oil to be there. And .. also agreed, cleaning it too much is a waste of time.
  9. #9 Re: Lower intake manifold question?
    Sep 2014
    United States
    Thanks everyone this forum has been extremely helpful. I can't wait to have this car back up and running.
  10. #10 Re: Lower intake manifold question?
    Soooo are you putting a new upper on it and switching out that big stovepipe? If not.. you should block the coolant ports to bulletproof it.
    Search on my name, "ea sy" without spaces and look for modding a lim.
  11. #11 Re: Lower intake manifold question?
    Enfield, CT
    Quote Originally Posted by Turbocharged400sbc View Post
    This only happens if you don't know what your doing. I sand blast it then jet wash and use air to blow it out to verify no glass is left behind. The engine shop I do this at is owned by my buddy who's done engine rebuild's for 30+ years.
  1. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  2. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  3. lower intake manifold job
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 10:22 PM
  4. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
