Thread: Throttle Body Screen Removal
Results 1 to 20 of 34
  1. #1 Throttle Body Screen Removal
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I know I know.. this has been discussed before
    I have seen some guys say they have issues, and some say that the car runs just fine. I have also seen that 97 and 98 cars may have issues where as later years do not due to a different MAF/screen setup in the throttle body.
    Just looking at ZZPs flow results from removing the screen, they gained 11.2% flow on an L67 TB. Seems pretty good and worth it if the fuel trims don't get thrown out of wack (which I could monitor I guess with the wideband).
    If you are really against it, I am definitely willing to listen. But would love some experience or supporting evidence why I'll have issues on my 99 GTP.
    Thanks!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Throttle Body Screen Removal
    Antioch, IL
    Id love to see the turbo guys reviews
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Throttle Body Screen Removal
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by ITHURTZ View Post
    In a good way or bad way?
    2002 GTP sedan:
  4. #4 Re: Throttle Body Screen Removal
    Pennsylvania, USA
    I've never looked closely because I personally wouldn't take mine out, but is it replaceable after it's been removed? If so I'd just try it out, if not then maybe wait for a good deal (or go to a junkyard) and buy a spare to test it out on.
    I would have to say that I'm against it. The function of the screen is to make the air coming into the intake laminar or "smooth and even" just before the MAF sensor to ensure the sensor gets an accurate reading at any engine RPM (and intake air velocity). A relatively smooth and straight intake would help achieve a similar effect, but it's very difficult to make an intake that can itself provide a laminar flow of air at all intake velocities. Any bump or ridge will create turbulence that will increase or decrease depending on those velocities, so even if the MAF sensor is relatively accurate at idle (giving the impression that removing the screen has done no harm), it may become inaccurate as you accelerate and go into WOT, which in turn won't allow the PCM to determine the correct amount of fuel to inject.
    Sorry for the long-winded explanation :P Really though, just because I wouldn't doesn't mean you can't or shouldn't, I'd just personally make sure I had a way to "go back" if I didn't like the results. Scan for KR if you decide to, and maybe even monitor the MAF signal as you drive around. It will let you see if it's causing any problems not having the screen in place.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  5. #5 Re: Throttle Body Screen Removal
    I live here. DirtDog's Avatar
    Jun 2012
    I agree. I wouldn't remove it. I did a lot of reading about it on ls1 tech due to the MAF I'm about to switch to. I'd prefer to have the honey comb in there. In the near future I'm going to put a different style of honeycomb in....but it is needed. Especially at higher RPMs.
  6. #6 Re: Throttle Body Screen Removal
    Leave it.
  7. #7 Re: Throttle Body Screen Removal
    Antioch, IL
    Quote Originally Posted by 97AutoXVette View Post
    hopefully positive, im sure there would be a difference from be sucked through, vs shoved through.
  8. #8 Re: Throttle Body Screen Removal
    Mar 2014
    Cincinnati, OH
    Appreciate all the info guys. I don't plan on taking mine out... yet haha.. maybe someone will see this thread who has taken it out and monitored AFRs up through WOT and can comment as well.
    Another thought is if the straightening effects are needed, I wonder if there is another way to do it that is less restrictive than the screen and still achieves the same result. (like 4 straightening walls or something right in the center of the flowpath, instead of all of the little "cross-hars" throughout the entire flowpath with the screen).
    2002 GTP sedan:
  9. #9 Re: Throttle Body Screen Removal
    Buffalo
    Laminar flow
  10. #10 Re: Throttle Body Screen Removal
    Jun 2012
    My question....what kinda mods are u doing, done, or planning to do where the screen would become a restriction
  11. #11 Re: Throttle Body Screen Removal
    May 2012
    Where winter never ends
    ^^ What he said... The amount of restriction is work the laminar flow... ill just turn my boost up a click to overcome the "restriction"
    2000 Regal - Winter Beater
  12. #12 Re: Throttle Body Screen Removal
    Feb 2010
    TN
    I am with Nik it smooths out the air flow forcing turbulent air in causes havoc. Think about take a sip of water from a garden hose from the side like normal, them try pointing it directly in you wide open mouth. I tries taking it out car ran like crap and mpg suffered, so I put it back
  13. #13 Re: Throttle Body Screen Removal
    Arizona
    It's the lower rpms---idle light cruise, startup areas are the reason for the screen. There are more efficient screens out there to use that have deeper but more open cells. High Rpm operation however on 99% of maf's are where they thrive. Turbo apps though do better on speed density with no screen
  14. #14 Re: Throttle Body Screen Removal
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Leave it be. You will see little to zero change. I did it once and it was fine for a year and then I get a weird idle miss / shake. Put the screen back in and everything was fine again.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  15. #15 Re: Throttle Body Screen Removal
    I stopped reading at "ZZP results"
  16. #16 Re: Throttle Body Screen Removal
    Feb 2010
    TN
    Quote Originally Posted by blueguy View Post
    I love it LOL!
  17. #17 Re: Throttle Body Screen Removal
    Mar 2014
    Cincinnati, OH
    I totally knew that someone was going to comment about the ZZP results ... How could they fudge those though?!?!
    2002 GTP sedan:
  18. #18 Re: Throttle Body Screen Removal
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    If they post it on the internet it has to be true. Everything on the internet is real.
    04 GTP -HAI, 1.9 rockers.
  19. #19 Re: Throttle Body Screen Removal
    Feb 2010
    TN
    Quote Originally Posted by SnowTh1ef View Post
    Didn't George Washington say that?
  20. #20 Re: Throttle Body Screen Removal
    Jul 2012
    Chicago
    I thought it was Julius Caesar.
    -Carl
  1. Ported throttle body screen
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 10:29 AM
  2. Throttle body screen
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2011, 03:51 PM
  3. throttle body screen
    By danamn6677 in forum General Tech Discussion
    Last Post: 09-11-2010, 01:05 AM
  4. throttle body screen
    Last Post: 11-08-2008, 08:46 PM
