Thread: Throttle Body Screen Removal
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Throttle Body Screen Removal
    Mar 2014
    Tucson
    Abe Lincoln.
    Check his blog.
  2. #22 Re: Throttle Body Screen Removal
    Antioch, IL
    2009 Challenger SRT8
    Expert at being gay.
  3. #23 Re: Throttle Body Screen Removal
    Antioch, IL
  4. #24 Re: Throttle Body Screen Removal
    Arizona
    Get the saxon pc honeycomb. I run it on my setup atm couldn't be happier with it.
  5. #25 Re: Throttle Body Screen Removal
    FWIW if you are looking for someone that did it.. I pulled the screen at one point on my Bonnie while it was stock for the most part. Found it felt like a lot more power, ended up being the maf not reading properly and the engine was running scary lean. Luckily I was watching things and got it back in.
    Most of the time you notice things leaning out from pulling it. I doubt it's that much increased airflow and moreso the lack of good readings.
  6. #26 Re: Throttle Body Screen Removal
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Makes sense. Thanks Bill
    And thanks for all the responses. I am convinced (to leave it in)
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  7. #27 Re: Throttle Body Screen Removal
    Feb 2010
    TN
    Bill whats you take on the Saxon honeycomb?
  8. #28 Re: Throttle Body Screen Removal
    Feb 2010
    TN
    Just went to Saxon's site how do I know which one I need?
  9. #29 Re: Throttle Body Screen Removal
    Antioch, IL
    read the dam links I posted, people cant comment on saxon hc when then dont run it or have enough knowledge on it or exactly how it works.
  10. #30 Re: Throttle Body Screen Removal
    Arizona
    I have experience with it like I mentioned above
  11. #31 Re: Throttle Body Screen Removal
    Like said.. I've never run anything but a stock screen. No info about Sax's.. defer questions to the guy that used it ... He likes it
  12. #32 Re: Throttle Body Screen Removal
    Kemmerer, Wyoming
    I had mine out for a while and was learning to tune with the dhp concurrently. I had a really hard time getting my maf dialed in, which could have been the tuning learning curve and my own failure. I sold the dhp and bought an hp tuner and overkill started tuning. the maf would get close but would never come in until I put the honeycomb back in. making maf adjustments now usually is very rapid and comes in within 2 or 3 adjustments, not like before where overkill made like 8 adjustments, and never coming in to where it should have been.
    edit: I know it's an old post, just wanted to share my .02.
  13. #33 Re: Throttle Body Screen Removal
    Antioch, IL
    thread is 2 years old private................
  14. #34 Re: Throttle Body Screen Removal
    Kemmerer, Wyoming
    Quote Originally Posted by ItHurtz View Post
    Thank you captain obvious
  1. Ported throttle body screen
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 10:29 AM
  2. Throttle body screen
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2011, 03:51 PM
  3. throttle body screen
    By danamn6677 in forum General Tech Discussion
    Last Post: 09-11-2010, 01:05 AM
  4. throttle body screen
    Last Post: 11-08-2008, 08:46 PM
