Thread: Battery dies after startup what could it be? Altenator checks fine
Results 1 to 20 of 22
  1. #1 Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Tryna to diagnose my issue with my battery:
    Ok starters its a new battery i got from the auto parts store 2 days ago because my battery died on me coming home so i replaced that i even replaced the altenator and it checks out fine the alt is a 99+ altenator do i need the 99+ plug/harness for that alt? Could it be a bad fuse? Checked my grounds even cleaned them but still battery drain im reading 11.4 on the volts and it goes down through time...any ideas? Could my rewire to my fuel pump cause this? Any suggestions? Thanks!
    Sent from my LG-E980 using Tapatalk
  2. #2 Re: Battery dies after startup what could it be? Altenator checks fine
    you need to find whats drawing the power. how is your stereo hooked up? you got amps and stuff?
  3. #3 Re: Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Scotty i have a stock stereo any other ideas the battery starts after about 5- 10 mins of the car on and starts draining slowly
  4. #4 Re: Battery dies after startup what could it be? Altenator checks fine
    its a pain in the ass but you need to test both fuse boxes key off, to see whats lighting up, and if it should be. theres only a few hot fuses car off. one for some reason is still drawing power.
    a ohm meter will tell you just how much power is being taken. a test light will only let you know if its hot or not.
  5. #5 Re: Battery dies after startup what could it be? Altenator checks fine
    SWPA
    Scotty, I think you are misreading what he is saying. Its not a draw with the car off, it is a draw with the car running. Sounds like the alternator is not charging. Doesn't mean the alternator is bad, but it could be a bad connection going back to the battery. I haven't messed with anything electrical on these cars yet so I don't know if there is an alternator fuse/fusible link that could be causing your issue. I know on my Stealth I once popped the fusible link and my alt couldn't charge the battery until that was replaced.
  6. #6 Re: Battery dies after startup what could it be? Altenator checks fine
    it dont really say running and or off. battery's get old and quit when they feel like it, if the battery was old and shot.
    i assume its car off if its at 11.4 volts. if the alts tests fine it should show over 12 to 14 volts at the battery engine running.
  7. #7 Re: Battery dies after startup what could it be? Altenator checks fine
    SWPA
    Title says "dies after startup."
  8. #8 Re: Battery dies after startup what could it be? Altenator checks fine
    who takes the title seriously lol
    but most cars wont even run on less then 12 volts.
    being you had the engine out and issues with the starter and stuff, it is possible somethings not hooked up right. you do have the battery cable from the alt to the top of the fuse box hooked up right?
  9. #9 Re: Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Yes
  10. #10 Re: Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Update: i said f**k it and wired my altenator to my positive side of my battery and walla the volts are at 14 its a short somewhere on that alt wire
  11. #11 Re: Battery dies after startup what could it be? Altenator checks fine
    nice, that will work.
  12. #12 Re: Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Yeah but scotty got a question: if my if i dont raise the rpms with the gas it the volts drop but when i rev or mash on the gas the volts raise quickly back to 14 volts any reason why
  13. #13 Re: Battery dies after startup what could it be? Altenator checks fine
    you have a cam, and a low idle?
    the fuse box could be the problem with the cable.
    in older cars, they would drop to 12+ volts at idle and go up with the rpm's why we hold the gas @ 1500 rpm's when jump starting a car, so it gets the full voltage.
    my regal does this to a point, lights on the volts drop, turn em off the volts go back up, lower at idle then goes up a bit driving. its just the alt spinning faster and making more power.
  14. #14 Re: Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Make sense ! Idc what they say about you scotty you my dogg!!
  15. #15 Re: Battery dies after startup what could it be? Altenator checks fine
    SWPA
    As I said, it sounded like the alt wasn't charging the battery for some reason. Glad you got it solved (if not temporarily):thumbsup:
  16. #16 Re: Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Yeah stealth idk alt checked out fine at the auto parts store
  17. #17 Re: Battery dies after startup what could it be? Altenator checks fine
    was it off the car when tested? if so thats why
    something from the fuse box to the battery is off kilter.
  18. #18 Re: Battery dies after startup what could it be? Altenator checks fine
    SWPA
    Quote Originally Posted by jayroca View Post
    The alt is obviously fine if running a wire directly from it to the battery solved your issue. Your problem lies in the wiring/fuse box like Scotty said.
  19. #19 Re: Battery dies after startup what could it be? Altenator checks fine
    Banned
    Jan 2013
    maryland
    Should i do the big three? What is need to be done for it?
  20. #20 Re: Battery dies after startup what could it be? Altenator checks fine
    older high amp alt 0 gauge wire highest cranking amps you can find that fits....
    ITHURTZ I think did a good job on his electrical improvements when he went turbo
  1. Grandprix Chugging after startup...dies
    By ajc549FF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2013, 04:56 PM
  2. car occassionally dies on startup
    By FX4 Level II in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2012, 10:37 AM
  3. Replies: 1
    Last Post: 02-08-2012, 10:09 PM
  4. starts/ dies x10 then is fine
    By ItHurtz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  5. New alternator, new battery, car still dies.
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2010, 12:48 AM
