Thread: ignition control module question
Results 1 to 5 of 5
  1. #1 ignition control module question
    Sep 2013
    Iowa
    1996 grand prix se 3100 engine. I'm having issues with the car reaching cruising speeds. Car seems to bog down quite a bit like it's not getting enough spark. This only happens when the car is in closed loop mode. When I unplug the O2 sensor to make the car run in open loop mode it run flawlessly.
    Does the ignition control module work differently when the car is in closed loop mode?
  2. #2 Re: ignition control module question
    Mar 2012
    NC
    No but the O2 sensor certainly does.
  3. #3 Re: ignition control module question
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    unplug your maf and see if it fixes it. sounds like a bad maf to me.
    04 GTP -HAI, 1.9 rockers.
  4. #4 Re: ignition control module question
    Sep 2013
    Iowa
    New mass air flow and I just replaced the oxygen sensor. This car has me stumped.
  5. #5 Re: ignition control module question
    Sep 2013
    Iowa
    An update of what I have found. I took the ICM out and had it tested, came back good. But I still decided to go to the junkyard and grab one. Got one off a running car and got a knock sensor as well put them both on the car, still bogs down during acceleration. So I unhooked the knock sensor to put it back in open loop and pull the air filter out. Drive the car around and of course it drives perfect like it did before in open loop. Shut it down and let it cool for 15 minutes then hook the knock sensor back up but keep the air filter out. Car is now in closed loop, drive it around and it runs perfect now. Got home cleaned the air filter really good put it back in and the car is good to go.
    I'm not sure if the computer had to learn the new parts or what but it's fixed and that's all I care about.
  1. ignition control module EMERGANCEY
    By Myers1985 in forum General Tech Discussion
    Last Post: 12-12-2016, 02:00 PM
  2. Looking for a 3800sc ignition control module
    By tweeder in forum Wanted To Buy - Parts
    Last Post: 02-28-2014, 11:33 PM
  3. Possible Ignition control module problems?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 05:04 PM
