Thread: Best way to pull Engine and Trans?
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Best way to pull Engine and Trans?
    Helps you to shoe horn that baby right in.
  2. #22 Re: Best way to pull Engine and Trans?
    Sep 2014
    United States
    Thank you Sir for the knowledge nugget. Where exactly did you mount the chain to the head using that leveler and what size bolts are they. I will snag one of those babies. that will definitely help when putting it back in.
  3. #23 Re: Best way to pull Engine and Trans?
    SE Level Member LHRxXD3adXx's Avatar
    Oct 2014
    While its out it wouldn't hurt to replace the water pump since its just right there unless u have already replaced it. I would also highly recommend to do the timing belt damper since they are the ones that wear out and will make u do the whole timing. These are just things i would do while its out. Just so much easier than when it sits on the car. Good luck
  4. #24 Re: Best way to pull Engine and Trans?
    If you have the brackets off, go right to the end of the head. EGR would also need to be off, or you could do it the way I do which uses the egr to hold the chain, but it can be a little sketchy and troublesome if you hurt the tubes to it. I just use the accessory bolts, since the brackets are off..you have bolts that fit just laying around.
  5. #25 Re: Best way to pull Engine and Trans?
    Sep 2014
    United States
    Quote Originally Posted by LHRxXD3adXx View Post
    The water pump was recently replace by the previous owner. But since I bought a complete engine gasket kit from ZZP I will use the rubber gasket. The one on there now looks like a paper one with RTV every where. Should I also consider doing the Head gaskets? The car only has 151k but I am not quite sure how the previous owner took care of the car.
  6. #26 Re: Best way to pull Engine and Trans?
    No need to touch the head gaskets. I like the idea of taking the RTV out, that's a mess trying to clean it up in the engine bay.
  7. #27 Re: Best way to pull Engine and Trans?
    Sep 2014
    United States
    Now that the engine is out and I can really inspect it. I can't really tell where all the oil leaks are coming from. I can see where the UIM and LIM are leaking. The valve covers are leaking. But also I can see where the front of the engine is wet with oil and especially down by the Oil pressure sensor. This is going to be a fun project.
  8. #28 Re: Best way to pull Engine and Trans?
    Soooo here's some stuff to consider.
    #1 At Advance Auto a lower conversion gasket kit has front and rear covers, water pump and oil pan gasket for less than the pan gasket by itself.
    #2 Please, change the rear engine cover gasket. These are known to seep and cause plenty of other issues.
    May as well do the front timing cover gasket, water pump, valve covers, LIM's etc and the rear cover then pan gasket while it's out.
  9. #29 Re: Best way to pull Engine and Trans?
    hangover park IL
    Cs9917 felpro part number
    ~James~ Psychotic Gearhead
  10. #30 Re: Best way to pull Engine and Trans?
    Sep 2014
    United States
    Thanks for the help everyone. I will swing buy and pick up the felpro gaskets tonight. I should have time to tackle it this weekend. Also thanks for the part number that makes life easy.
  11. #31 Re: Best way to pull Engine and Trans?
    Sep 2014
    United States
    Before pictures of the engine up close with all of the oil and leaks. I should have washed it while it was in the car. It would have made cleaning everything else up a little easier.
  12. #32 Re: Best way to pull Engine and Trans?
    In my eyes, you get bonus points for not destroying the wire that goes to the knock sensor.
  13. #33 Re: Best way to pull Engine and Trans?
    Enfield, CT
    How to you f up and destroy the knock sensor wire? I think you'd have to be really stupid to do that
  14. #34 Re: Best way to pull Engine and Trans?
    **Runs across street to check for one in corn field***
  15. #35 Re: Best way to pull Engine and Trans?
    Enfield, CT
    LMAO!
  16. #36 Re: Best way to pull Engine and Trans?
    not sure if its the best way, but its the fastest.
  1. How to pull and engine and transmission out the top
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 12-06-2013, 09:52 PM
  2. Engine Removal: Should I pull the engine or drop the sub frame?
    By acidcrashdburnd in forum General Tech Discussion
    Last Post: 03-13-2013, 03:29 PM
  3. Pull engine, trans or both
    By cogsracing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2011, 06:30 AM
  4. Engine and Trans pull... SAME TIME?
    By nathangartz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 09:40 PM
  5. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
