If you have the brackets off, go right to the end of the head. EGR would also need to be off, or you could do it the way I do which uses the egr to hold the chain, but it can be a little sketchy and troublesome if you hurt the tubes to it. I just use the accessory bolts, since the brackets are off..you have bolts that fit just laying around.
