Thread: 2007 GP Base Wheel Hub Assembly
Results 1 to 15 of 15
  1. #1 2007 GP Base Wheel Hub Assembly
    Jul 2013
    Richmond, VA
    Can anyone tell me if an ABS hub will fit a GP that does not have ABS? I would assume the only difference would be the ABS sensor, but I would like some conformation.
  2. #2 Re: 2007 GP Base Wheel Hub Assembly
    Mar 2012
    NC
    Sure will...just cut off the pigtail...or secure it so you can retain warranty.
  3. #3 Re: 2007 GP Base Wheel Hub Assembly
    Jul 2013
    Richmond, VA
    Thanks for the quick response. Need to get them shipped asap so I can swap them on Sat.
  4. #4 Re: 2007 GP Base Wheel Hub Assembly
    Mar 2012
    NC
    No problem. Have fun. And make sure you torque the axle nuts or you could damage the new bearings.
  5. #5 Re: 2007 GP Base Wheel Hub Assembly
    I've cut plenty of piggy tails off.
    Torque a hub..lol
  6. #6 Re: 2007 GP Base Wheel Hub Assembly
    Jul 2013
    Richmond, VA
    The worst part about this is I just had the entire da#ned subframe out to replace the flywheel. I just replaced that, the motor mount, the tie rod ends, sway bar end links/bushings, and the ball joints. Wish I would have noticed when I had the knuckles off already.
  7. #7 Re: 2007 GP Base Wheel Hub Assembly
    Jul 2013
    Richmond, VA
    So I replaced the hubs over the weekend and brought it back in for the safety inspection and alignment today. Apparently the camber was off on both left tires. They needed to install a special bolt in order to set the camber for both knuckles. Does that sound right?
  8. #8 Re: 2007 GP Base Wheel Hub Assembly
    Called a camber kit or they can slot the struts.. A camber kit is like $15-20 each so don't let them rape you on the price. Hell don't let them charge you for labor either or take it home.. And swap the bolt in yourself and take it back for a alignment. Yes it's rather normal.
    04 Comp G.
  9. #9 Re: 2007 GP Base Wheel Hub Assembly
    Jul 2013
    Richmond, VA
    I figured that the kit was cheap. They are charging $48 per wheel, which I thought was ridiculous, but if I had them pull it they were going to charge me with an alignment check fee of $40. Then I would have to pay another $90 for an alignment after I installed the kit. So I just had them do it because the OOP would have been close either way. This is why I work on my own vehicles.
  10. #10 Re: 2007 GP Base Wheel Hub Assembly
    Sooo most wouldn't pull the knuckle off to do that work.
  11. #11 Re: 2007 GP Base Wheel Hub Assembly
    Jul 2013
    Richmond, VA
    The alignment or the hubs?
  12. #12 Re: 2007 GP Base Wheel Hub Assembly
    You said you ganked the sub to do the flex. I would have left the knuckles on the struts. Only because once you dink with them..you need an alignment.
  13. #13 Re: 2007 GP Base Wheel Hub Assembly
    knuckles stay on for a hub swap.
    buy your own camber bolts, install them, then go back for the alignment. its just a bolt with a cam gear on it. google it.
  14. #14 Re: 2007 GP Base Wheel Hub Assembly
    Orrrr grind out the oval of the strut a little. Cheap man's camber kit.
  15. #15 Re: 2007 GP Base Wheel Hub Assembly
    Jul 2013
    Richmond, VA
    I still had to get an alignment from when I dropped the subframe to do the flex plate (other thread). I also did the ball joints and outer tie rods while it was out. Otherwise I would have just popped the tie rod ends off when I did the hubs over the weekend.
  1. 2007 GP Base coolant leak
    By lawadm1 in forum General Grand Prix Discussion
    Last Post: 04-02-2014, 10:57 AM
  2. 2007 GP Base
    By jlgp2007nc in forum Members Rides
    Last Post: 03-07-2013, 01:16 PM
  3. 2007 Base overheating Issue
    By bdkruse in forum Introductions/Noob Questions
    Last Post: 02-04-2013, 10:10 AM
  4. Went from 2007 Base to 2008 GXP
    By jeangreyfan in forum Members Rides
    Last Post: 05-12-2012, 11:45 PM
  5. 2007 Base vs 1999 GTP
    By Brien in forum Off Topic Discussion
    Last Post: 12-24-2010, 01:02 PM
