Thread: 2007 GP Base coolant leak
Results 1 to 11 of 11
  1. #1 2007 GP Base coolant leak
    Jul 2012
    Bloomington, IL
    We have a 2007 GP Base with 170,000 miles, and it has a pretty good coolant leak. If you look under the hood on the pulley side, you can see it just about everywhere, like it must be spraying while it's running. On the belt. other pulley's, cables, etc. I have to admit I do not know which one is the water pump, but it looks like it may be starting where the hose from the lower radiator (passenger side) runs up into the engine. The hose looks tight, and doesn't appear to be leaking. I stuck my hand down there and it was sticky, but not wet.
    We're going to be taking it in Friday, but I wondering if there was something you guys could think of that I could check? Or any thoughts as to what it could be?
  2. #2 Re: 2007 GP Base coolant leak
    Coolant elbows!
    04 Comp G.
  3. #3 Re: 2007 GP Base coolant leak
    Jul 2012
    Bloomington, IL
    Is there a way that I can verify that it's the coolant elbows on my own??
  4. #4 Re: 2007 GP Base coolant leak
    Enfield, CT
    Yea put dye in the cooling system and look for dye marks
  5. #5 Re: 2007 GP Base coolant leak
    Jul 2012
    Bloomington, IL
    I think I found them. Behind the alternator there are two hoses, one is nice and clean, and the other is just caked in coolant.
  6. #6 Re: 2007 GP Base coolant leak
    Quote Originally Posted by lawadm1 View Post
    Bingo you win.
    Grab some from the parts store.. There's aluminum heater elbows.. Cost like $12 and so far they solve the issues with the brittle plastic ones breaking. Congrats you just saved yourself a bunch of money that the dealer would of charged you lol
    04 Comp G.
  7. #7 Re: 2007 GP Base coolant leak
    To much work guy ^
    Passenger side of the engine bay toward the back of the fire wall.. You'll see the accessories tensioner.. And then you should be able to see to coolant elbows (more then likely yours are plastic) wipe the error and see if there signs of coolant. This are very common and wash to replace.
    04 Comp G.
  8. #8 Re: 2007 GP Base coolant leak
    Jul 2012
    Bloomington, IL
    So is the next thing you are going to tell me that they are easy to replace? It's the one furthest from the alternator towards the overflow. It's even wobbling if you move it around.
  9. #9 Re: 2007 GP Base coolant leak
    Yup easy peazy
    04 Comp G.
  10. #10 Re: 2007 GP Base coolant leak
    http://www.grandprixforums.net/threa...coolant-elbows
    47065HP is the p/n for the elbows
    it comes with both..so go ahead and replace both elbows.. a little bit of oil or Vaseline on the elbows orings will help them slide easier
    04 Comp G.
  11. #11 Re: 2007 GP Base coolant leak
    Jul 2012
    Bloomington, IL
    Ended up taking this one in so that I knew for sure what the issue was. It ended up being the water pump. Also the front bushings are shot. = Bend Over
  1. 2007 base model for sale5300 OBO
    By kycycles in forum For Sale - Vehicles
    Last Post: 06-06-2013, 01:58 PM
  2. 2007 GP Base
    By jlgp2007nc in forum Members Rides
    Last Post: 03-07-2013, 01:16 PM
  3. 2007 Base overheating Issue
    By bdkruse in forum Introductions/Noob Questions
    Last Post: 02-04-2013, 10:10 AM
  4. Went from 2007 Base to 2008 GXP
    By jeangreyfan in forum Members Rides
    Last Post: 05-12-2012, 11:45 PM
  5. 2007 Base vs 1999 GTP
    By Brien in forum Off Topic Discussion
    Last Post: 12-24-2010, 01:02 PM
