Thread: Heavy Isolated Misfire Under Load
Page 8 of 10 FirstFirst ... 678910 LastLast
Results 141 to 160 of 197
  1. #141 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    I forgot I have an ICM I could sell you too lol. I gotta double check if the 97 year works for other years. What year is yours again?
  2. #142 Re: Heavy Isolated Misfire Under Load
    It's the same
  3. #143 Re: Heavy Isolated Misfire Under Load
    SE Level Member jimzssei's Avatar
    Sep 2014
    I know I'm late to this party, and you guys don't know me at all, but I just experienced a "misfire under load/boost" on my 02 ssei. The control module and coils were good but...
    The heat sinc/bracket was loose, causing the misfire. It never popped a cell. The misfire DEFINITELY hit hard, like a fuel cut, or shutting the key off/on quickly. Once I tightened the control mod bracket the problem was eliminated... Gone.
    Just wanted to share!
    Sent from Ohio
  4. #144 Re: Heavy Isolated Misfire Under Load
    iirc there should also be a ground wire that goes by the icm bracket too.
  5. #145 Re: Heavy Isolated Misfire Under Load
    All good suggestions.
  6. #146 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I don't see a heat sink but the ICM is tight on the bracket. The ground wire is also hooked up.
  7. #147 Re: Heavy Isolated Misfire Under Load
    Is the icm 7mm retaining bolt snug? This is the bolt that holds the wiring connector to the ICM
  8. #148 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Quote Originally Posted by Jomamma View Post
    Does the ground wire have a giod connection tho? I would sand it down a little just to be sure
    Sent from my SCH-S720C using Tapatalk 2
  9. #149 Re: Heavy Isolated Misfire Under Load
    Ground can be left unhooked. Not telling you how I know.
  10. #150 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Yes the 6.5mm* bolt is snug
    Yeah I left it unhooked by accident after one of the 100 times I had to pull the valve cover. Didn't notice a difference
  11. #151 Re: Heavy Isolated Misfire Under Load
    It's a 7mm ... might wanna check that for rust..lol
  12. #152 Re: Heavy Isolated Misfire Under Load
    Mar 2014
    Tucson
    I JUST reconnected mine after doing the VC gaskets. Didn't notice any problems before. I figured it would be a good idea to reconnect it though. LOL!
  13. #153 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I should've known better than to challenge your knowledge of various 3800 bolt sizes.
  14. #154 Re: Heavy Isolated Misfire Under Load
    LOL.. there's a few that will trip ya up.
    Like alt/tensioner bracket bolt head sizes are different 97/98ish vs 00+
  15. #155 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    So who wants my money? Still in need of an ICM.
  16. #156 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Do you want just the ICM? I's got one to sell but if, for whatever reason, you want the bracket and coils LMK. I'll give you a better deal then I posted
  17. #157 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    No bracket or coils needed. Just the ICM
  18. #158 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    All those aboard the ICM train may now get off.
    Swapped it out same problem.
    The injector o-ring is messed up on cyl 1 gonna replace that tomorrow.
  19. #159 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    That's a bummer man. have you swapped injectors to see if it's misfiring?
  20. #160 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Yes I have.
    My aero force isn't picking up the misfire now, or at least its not telling me which cylinder anymore.
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
