Thread: Heavy Isolated Misfire Under Load
Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 197
  1. #101 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Quote Originally Posted by Drunkie View Post
    Everything mechanical seems fine then. Going back to what bill said earlier...You have a huge vacuum leak somewhere...or something electrical.
    I'm feeling like its the cam even though the lifter came up to the same height as the others.
    When I had it apart, I could see the can lobe through the bottom of the lifter valley. So I ran my finger nail across it horizontally. I felt small ridges towards the edge of the cam lobe. So I did the same on the opposite side of the lifter valley and it kinda felt the same.
  2. #102 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Well since the issue still persists, just pull the cam and if it's fine then you'll have some ease of mind
  3. #103 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Well I don't exactly have the time to pull the cam. It is my daily and winter is approaching.
  4. #104 Re: Heavy Isolated Misfire Under Load
    Thought this cam was checked rough the lifter bores?
  5. #105 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Quote Originally Posted by Jomamma View Post
    you've checked everything else so far so I would check the cam now
  6. #106 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Quote Originally Posted by 98NoBallzVet View Post
    what the hell? you can't just check the cam through the bores man. Pulling out the cam and inspecting it is the correct way to go. Trust me.
  7. #107 Re: Heavy Isolated Misfire Under Load
    was this ICM ever changed I don't remember
    I don't think its cam after you marked them lifters it seems like its fine.
  8. #108 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I didnt put a borescope in there if that's what your asking. I could see the cam through the lifter bores and it looked alright.
  9. #109 Re: Heavy Isolated Misfire Under Load
    Quote Originally Posted by HighOctaneRacing View Post
    Never used a camera? you can do the same through the plug holes to check piston tops....... settle guy it would be a hell of a lot easier and faster than pulling the cam!
  10. #110 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I could see the lobe clearly from the hole in the left middle part of the lifter valley. I don't think the camera would help any.
  11. #111 Re: Heavy Isolated Misfire Under Load
    never mind him, hes lost..........
  12. #112 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Plz tell me where I am.
  13. #113 Re: Heavy Isolated Misfire Under Load
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I'd be putting the bigger pulley back on seeing you said you saw no misfires with it and see how it runs again with it.
    Theres something going on there if you see misfire with the small pulley and not the bigger one.
    If it was the cam you would see missfire on either pulley I would think.
  14. #114 Re: Heavy Isolated Misfire Under Load
    bingo^
  15. #115 Re: Heavy Isolated Misfire Under Load
    Your cam is fine, I'm willing to bet...the head and lifters were fine too.
  16. #116 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Im positive it has nothing to do with the pulley. It was missing on the stock pulley.
  17. #117 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    **** I just remembered some cams cause misfire codes lol. If this is the issue, tune is needed
  18. #118 Re: Heavy Isolated Misfire Under Load
    Dec 2011
    Ontario,Canada
    Put a new lifter in today. Took it for a quick ride. Went wot a few times. And it felt good.
    Came back home put the new pulley on and the second time I went wot with the new pulley it started to misfire again.
    I wanna say its the cam but I checked the height the lifters were rising as I turned over the motor and everything checked out. I marked the highest point on the lifter on a different cylinder then swapped the lifter over to the suspected bad lifter. When I turned it over it came up to the same spot.
    Damn this car man.
    Well in this post you said it "felt good" then you said "Came back home put the new pulley on and the second time I went wot with the new pulley it started to misfire again."
  19. #119 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I didn't put an aftermarket cam in.
    Quote Originally Posted by 231FUN View Post
    I think I was just a fluke. I took it for 5 minute drive after letting idle. I did like 2 wot bursts. I probably just didn't drive it enough to notice it after I put it back together.
  20. #120 Re: Heavy Isolated Misfire Under Load
    Mechanical aspects of an engine don't to just work then not work. I think this issue is now outside the block
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
