Thread: Heavy Isolated Misfire Under Load
Page 1 of 10 123 ... LastLast
Results 1 to 20 of 197
  1. #1 Heavy Isolated Misfire Under Load
    Howell, NJ
    My 97 gtp is having heavy misfires on Cylinder #1 when accelerating any harder than grandma mode. The problem began after my 1.9 Rocker Install.
    I re-inspected under the valve cover. I ruled out the spark plug, the wire, the coil pack and the ICM. I have no codes besides the misfire.
    Any Ideas or suggestions will be greatly appreciated.
  2. #2 Re: Heavy Isolated Misfire Under Load
    Time to look at your fueling situation. Swap injectors...see if the issue follows.
  3. #3 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Quote Originally Posted by Drunkie View Post
    I agree and if not that look at the pushrods
  4. #4 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I found the problem. One of the pedestal spacers is missing. Which is odd because I remember taking the last one out of the packing.
    Anyway the box that had the packaging is at the dump now if it was in there.
    Where can I buy them?
  5. #5 Re: Heavy Isolated Misfire Under Load
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    might need to contact harland sharp.. Or maybe you could bring a normal spacer to a machine shop with a rocker spacer to have them machine in the curve?
    04 GTP -HAI, 1.9 rockers.
  6. #6 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    A normal spacer? Where would I get this normal spacer?
  7. #7 Re: Heavy Isolated Misfire Under Load
    Aug 2013
    Sandy, UT
    Quote Originally Posted by Jomamma View Post
    Like a bolt spacer from ACE or similar lol. like what we put in the accumulator for shift kit, and just have the curve machined into it. But since you already have one coming from HS you'll be good to go.
  8. #8 Re: Heavy Isolated Misfire Under Load
    Contact harland sharp, and I wouldn't drive the car until it is fixed.
  9. #9 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    At least you found the issue
  10. #10 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I already contacted them.
    I dont really have a choice, I have class and work and this is the only car I have available to me atm. I made my own spacer in the mean time and I disconnected the boost bypass solenoid.
    Quote Originally Posted by HighOctaneRacing View Post
    Tell me about it. I'm so relieved. Since friday every ounce of free time I've had has been put into that car. Im drained.
  11. #11 Re: Heavy Isolated Misfire Under Load
    see what happens when you work in the dark???
    good find tho.
  12. #12 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    good find tho.
    Thats what I've been telling myself all day.
    "Thats what I get for working in the dark"
    Hopefully I didn't bend the valve or damage a piston. That random noise I heard was knock due to the built up pressure not being exhausted quickly enough.
  13. #13 Re: Heavy Isolated Misfire Under Load
    I've seen two come up missing and I know they were installed.
    Hmmmm now who the hell did I give that bag of spare spacers to? Right..I'm the guy that had spares, and gave the bag to someone.......
  14. #14 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I hope its not in the engine somewhere.
    Harland sharp got back to me they're sending me one for the price of shipping.
  15. #15 Re: Heavy Isolated Misfire Under Load
    It's also not a straight spacer.. there's an angle. Which led to the great rocker issue of a few years ago.
  16. #16 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    So what's this issue and how can I prevent it ?
  17. #17 Re: Heavy Isolated Misfire Under Load
    Dude.. IDK.. it never happened to me directly. I was just the guy handing out pedestals. Had a gallon bag of them.
  18. #18 Re: Heavy Isolated Misfire Under Load
    Aug 2013
    Sandy, UT
    If yours is a newer set you have nothing to worry about. it was the original ones that first came out from HS that had an issue. Mine are great!
  19. #19 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Its all good . One will be here by Friday. Those guys over at Harland sharp are great.
  20. #20 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Put the new spacer in.
    Car still misses under throttle.
    Now I can see what everyone was talking about. The spacer I got had a little dot on one side. I guess I didn't have the revised set.
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
