Thread: Inline Fuel Pump
Results 1 to 14 of 14
  1. #1 Inline Fuel Pump
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Has anyone ever ran a performance inline pump? Such as a Bosch 040 044 or Deatschwerks 350iL?
    Wondering if that might be a better solution than a new in tank pump, just leaving the stock venturi/non venturi whatever it is to feed the powerful inline pump to feed a large injector E85 setup. Or if you'll just suck the stock pump dry. Any ideas?
    04 GTP -HAI, 1.9 rockers.
  2. #2 Re: Inline Fuel Pump
    Banned
    CT
    When running 2 pumps in line, your fuel supply is only as good as your weakest pump.
    With that said, the pump in the bucket will basically be running at like 0psi.
    Still... not ideal
    With the walbro 485 easily retrofitted into our systems, why would anyone sub ~750whp do anything else?
  3. #3 Re: Inline Fuel Pump
    Aug 2013
    Sandy, UT
    Gotcha. Was just curious to do something different haha. Still need to figure out what pump is going to work in my camaro.. Not sure if its more similar to a v8 camaro or more similar to other 3800 cars..
  4. #4 Re: Inline Fuel Pump
    Banned
    CT
    I got the idea for the 485 from a thread on LS1 tech regarding a guy with a turbo 4th gen.
    What are you aiming for anyhow? The 255 is good to like 500whp on e85.
  5. #5 Re: Inline Fuel Pump
    Aug 2013
    Sandy, UT
    I'm sure no higher than 500whp on corn in the next few years. Just a plain ol walbro 255 should easily go in the 3800 camaro canister you think?
  6. #6 Re: Inline Fuel Pump
    Banned
    CT
    I would bet that there are drop-in solutions for you.
  7. #7 Re: Inline Fuel Pump
    Aug 2013
    Sandy, UT
    I'm sure there are.. but from what I've seen or looked up no one can really say for sure if wbody/other 3800 stuff is drop in or the v8 stuff is drop in.. lol
  8. #8 Re: Inline Fuel Pump
    Are the 3800 vs V8 tanks even different? I would tend to think an inline setup would be more difficult then a drop in considering the car cam with a V8 option.
  9. #9 Re: Inline Fuel Pump
    Aug 2013
    Sandy, UT
    I know the v6/v8 pumps and canisters are different, partially because the ls1 is a returnless style and the 3800 is return.
  10. #10 Re: Inline Fuel Pump
    Feb 2009
    flintnasty MI
    Flowing 750whp worth of fuel powered by that tiny little pin inthat fuel can is not going to happen snowtard.
  11. #11 Re: Inline Fuel Pump
    Arizona
    Use the v8 assembly the simply make a return in the tank.
    Then use whatever pump u want . -8 line split into -6 at the rails and a -6 return should be just fine
  12. #12 Re: Inline Fuel Pump
    Aug 2013
    Sandy, UT
    Thats why I was asking. No need to be a dick.
  13. #13 Re: Inline Fuel Pump
    Aug 2013
    Sandy, UT
    Quote Originally Posted by 91parkave View Post
    ... My car is already plumbed for a return style fuel setup... I'm thinking an upgraded GTP pump is going to go in the canister. AEM 340 LPH or something.
  14. #14 Re: Inline Fuel Pump
    Banned
    CT
    Had my boost up to 28psi, ~85psi of fuel pressure.
    Held it like a champ, fuel pump was a rock star.
  1. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  2. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  5. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
