Thread: Trouble code P0455
Results 1 to 9 of 9
powerranger262 Trouble code P0455 12-04-2009, 10:30 AM
powerranger262 Re: Trouble code P0455 12-04-2009, 11:01 AM
a98gtp4u Re: Trouble code P0455 12-04-2009, 12:28 PM
cerick08GP Re: Trouble code P0455 12-04-2009, 12:30 PM
powerranger262 Re: Trouble code P0455 12-04-2009, 12:57 PM
Morris 04 GTP Re: Trouble code P0455 04-08-2010, 09:54 AM
johnniep Re: Trouble code P0455 04-11-2010, 08:59 AM
Morris 04 GTP Re: Trouble code P0455 04-12-2010, 06:39 AM
IrishPoe Re: Trouble code P0455 09-23-2014, 03:09 PM
  1. #1 Trouble code P0455
    SE Level Member powerranger262's Avatar
    Nov 2009
    2004 grand prix gt just failed emissions because of this:
    Trouble codes present
    P0455 EVAP control system leak detected (gross leak)
    Could this be from the ongoing gas cap light? Probably another sensor? Help soon or PONTIAC
  2. #2 Re: Trouble code P0455
    Nov 2009
    After some researching I came up with either the gas cap or vent solenoid valve. Anyone ever replace this or any how to's on it.
  3. #3 Re: Trouble code P0455
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    just replace the gas cap 4 now and see if the lite turns back on. they r cheap at autozone. start with the easiest and cheapest thing 1st.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  4. #4 Re: Trouble code P0455
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by powerranger262 View Post
    ...Umm
    This is just a thought, how about replacing the gas cap.
    How much more obvious could “PONTIAC” make it? Gas caps do go bad you know.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Trouble code P0455
    Nov 2009
    Tried three different ones already, gas cap light stays on. I've never had a gas cap "go bad" before, why should it, it's a gas cap.
  6. #6 Re: Trouble code P0455
    SE Level Member Morris 04 GTP's Avatar
    May 2008
    North Eastern CT
    I've got this same problem. It's been ongoing for a little over a year. I've replaced the gas cap but no such luck. The code keeps coming back. Where is the vent valve solenoid? I've done it on my truck but that was right out in the open under the bed. Anyone have an idea where it is so I can change it?
  7. #7 Re: Trouble code P0455
    SE Level Member johnniep's Avatar
    nova scotia
    had the same with my 02 gt.....a new gas cap and reset the code...stay cleared for an hour but i had to replace the evap .....remove or drop the inner liner from the back wheel well and it right there...reset the codes after.....same thing on my 05 silverado....159.00 for a new one but we used one for a surburban...49.00 plus a small piece of hose
  8. #8 Re: Trouble code P0455
    May 2008
    North Eastern CT
    Yeah I had to get the updated one for my 99 sierra, alot more money for the same piece as stock with a small length of heater hose included so you can put in spot with less dust. Stupid.
  9. #9 Re: Trouble code P0455
    Jul 2013
    Capron, IL
    We're talking about the canister purge valve?
  1. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  2. P0442 trouble code?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:33 AM
  3. P1810 Trouble Code - TFP Valve Position Switch Circuit
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2008, 11:03 PM
  4. General OBD-1 Trouble Code List
    By Sinister Performance in forum PCM Tuning
    Last Post: 02-22-2008, 06:09 AM
  5. General OBD-2 Trouble Code (DTC) list
    Last Post: 02-22-2008, 02:15 AM
