Thread: Steering wheel wobble. HELP!!
Results 41 to 60 of 77
  1. #41 Re: Steering wheel wobble. HELP!!
    time will tell. but i did hear that click when shifted in and out of gear lol so not all crazy lol
  2. #42 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    From the video is that a trans problem, or are you convinced the CV's are bad??
  3. #43 Re: Steering wheel wobble. HELP!!
    being i see the one part moving and the other not, then the click, its the axle in my opinion
  4. #44 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Dumb question: both ends of the shaft should move in unison, correct? No delay?
  5. #45 Re: Steering wheel wobble. HELP!!
    yup.
    if you put it in neutral, e brake on of course, and with two hands i bet you can make it move and click by twisting the one side to the trans.
  6. #46 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    While the car is in the air and moving the front wheels forward and reverse? Or pushing the actual car? I had it on stands last night and I could rotate my wheels, there was a delay before engagement in the trans.
  7. #47 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Is the axle supposed to be flush with the transfer case? It's removed about 1/4" from the case. From what I'm hearing it should be flush..
  8. #48 Re: Steering wheel wobble. HELP!!
    Get us a picture. The axle doesn't get all that flush. And if you'd like to be worried about how much an axle sticks out.. go look at the passenger side. You'll feel way better about the drivers side.
  9. #49 Re: Steering wheel wobble. HELP!!
    St. Louis
    No, axle will move in/out of the trans. case some. No transfer case unless 4x4, lol.. There is a c-clip at the end of the axle that hold it in the trans. It floats a bit.
  10. #50 Re: Steering wheel wobble. HELP!!
    Shhhh... c'mon guys.. you know he'll freak when he sees the pass side.
  11. #51 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    I already did haha. To remove the axle do I just give it a good tug until it pops out? Then to install the new one just push it in until I hear a click??
  12. #52 Re: Steering wheel wobble. HELP!!
    No.. you need to give the back of the inner cv a quick hit. That way you don't put any force on the compression clip until the quick hit. That's how the compress and come apart easy. DRiverside tend to be the fighter because you can't get in there well to do it.
    Gearwrench 82248 prybar is the champ of these axles ..
  13. #53 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    So I need to hit the axle outboard, right where it connects to the trans?
  14. #54 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Almost every article I read just says pry that fugger out.
  15. #55 Re: Steering wheel wobble. HELP!!
    you need to push it in, so its not resting on the clip, then pop it hard and quick to pop it past the c clip.
    you need a pry bar that you kick, or that tool bills got, and ill say that tool makes life easy.
  16. #56 Re: Steering wheel wobble. HELP!!
    Pressure on teh clip (pry type pressure) will make it stay in place and keep the compression clip from compressing. Trust me ...many have learned this the hard way.
  17. #57 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Driver Side Video:
    View My Video
  18. #58 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Passenger Side Video:
    View My Video
  19. #59 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Can you guys give those a watch? I appreciate the help, I just want to make sure I'm not totally off base before I dig into these...
    Is it clearly my axles, if so which one? or both?
  20. #60 Re: Steering wheel wobble. HELP!!
    can see a thing. to dark, to far away.
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  3. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  4. Can rack and pinion cause wobble in steering?
    By teejay in forum General Tech Discussion
    Last Post: 04-14-2013, 06:45 PM
  5. steering wheel help
    By ham4864 in forum General Tech Discussion
    Last Post: 11-27-2010, 07:32 AM
