Thread: Steering wheel wobble. HELP!!
Results 21 to 40 of 77
  1. #21 Re: Steering wheel wobble. HELP!!
    shift it in and out of reverse too, r to n to drive, back to N to R.
  2. #22 Re: Steering wheel wobble. HELP!!
    if it was a bad axle your feel it vibrating when on the gas.
    it could be a ball joint even, it does sound like a metallic click.
  3. #23 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Here's the motor:
    View My Video
  4. #24 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Here's the driver side CV:
    View My Video
  5. #25 Re: Steering wheel wobble. HELP!!
    yeah, motor looks good and tight. not flapping around.
    try watching the axle and lca of the side you hear it from. turn the wheels so you can see,
  6. #26 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Here's the Passenger side:
    View My Video
  7. #27 Re: Steering wheel wobble. HELP!!
    you called it the first time, bad axle. see how only 1/2 moves? the joint is bad.
    if you go watch the other side it wont do that.
  8. #28 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Now that I watch them both a couple times, they look similar. Are you saying passenger side is shot?
    It looks like only 1/2 moves in both.
  9. #29 Re: Steering wheel wobble. HELP!!
    dont think they should move much if at all. take it for a ride see if it vibrates when on the gas light, and hard, if it does vibrate, then coast in gear, if the vibration is gone its for a sure a bad axle.
  10. #30 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    I drove it earlier, that's how I noticed the clicking. I noticed it leaving from a stop.
    No vibrating at all though man.. even on the highway, I took it up to 100. There's just something not right. It's almost like they're not fully engaged. This is something new, could I have disconnected them too much when I dropped the subframe? The subframe was lowered all the way, once the rear 2 bolts were removed.
  11. #31 Re: Steering wheel wobble. HELP!!
    how far is all the way down???? you only supposed to drop the rear of the frame like 3 to 4 inches tops.
  12. #32 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Like I dropped that bi tch low... and my hubs/axles were still connected. I couldn't get clearance without doing it.
  13. #33 Re: Steering wheel wobble. HELP!!
    just thinking about the geometry of things, dont think that would even flex the axles. engine trans, lca's all bolted to the frame. so they never knew the frame dropped.
    the front sub frame mounts may tell a different story lol i bet they were un happy for sure.
  14. #34 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Yeah the front mounts probably were screaming haha.
    So what's your take. Is it an axle issue?? What side looks worse to you, it sounds like its coming from the passenger side. But the driver side is the one that has the axle separated from the transfer case.
    Should I take the passenger side hub off and play with the axle. I just don't know at this point...
  15. #35 Re: Steering wheel wobble. HELP!!
    drive it till it gets worse and vibrates. what id do, no sense in tossing money at what may not be a issue.
  16. #36 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Holy crap. Seriously? Will I lose any performance at all, or is it just basically dealing with the clicking??
    EDIT: It sorta hesitates from a dead stop too, which bugs me..
  17. #37 Re: Steering wheel wobble. HELP!!
    try cleaning the TB. last tune up was? it may be due.
    that click will get worse then vibrate if its going bad. id wait for some more signs of failure.
  18. #38 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    No no, tunes fine. It was dyno'd in May. I mean hesitated due to the axles it seems. I go to accelerate and there is a slight delay.
  19. #39 Re: Steering wheel wobble. HELP!!
    tune up....aka plugs and wires lol
    bad axles wont make it bog.
  20. #40 Re: Steering wheel wobble. HELP!!
    Jun 2013
    Metro Detroit
    Quote Originally Posted by Sallydoggs View Post
    Had new plugs and wires in May too lol. It's not bogging. Maybe it's in my head.
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  3. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  4. Can rack and pinion cause wobble in steering?
    By teejay in forum General Tech Discussion
    Last Post: 04-14-2013, 06:45 PM
  5. steering wheel help
    By ham4864 in forum General Tech Discussion
    Last Post: 11-27-2010, 07:32 AM
