Thread: Alternator Rewire Fuse?
Results 1 to 3 of 3
  1. #1 Alternator Rewire Fuse?
    SE Level Member TuKoolGTP's Avatar
    Nanamo, BC, Canada
    Anyone with the Alternator Rewire running some kind of an inline fuse?
    Custom CAI | PowrTuner | AL 104s | TBS | 3" DP | Res Del | 180 TS | 3.6 | PEM
  2. #2 Re: Alternator Rewire Fuse?
    Florida
    Yep, good idea to incase the alternator starts overcharging. I'm running 4ga with a 125amp fuse
  3. #3 Re: Alternator Rewire Fuse?
    Pennsylvania, USA
    It's a good idea if your wiring can't handle overcharging, just make sure you seal whatever fuse holder you use to prevent corrosion. I would use some liquid electrical tape.
    I don't personally use one, but I used welding wire rated to 300 amps to handle a HO alternator.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  1. Fuse tap for wiper fuse.
    By Stormhaven in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2013, 12:24 PM
  2. Rewire!
    By crysalis in forum Audio, Security & Visual Electronics
    Last Post: 09-14-2011, 08:54 PM
  3. DRL rewire
    By BadBoyPrix in forum General Tech Discussion
    Last Post: 03-14-2011, 05:11 PM
  4. Alternator Rewire w/ Pictures
    By abuckley1290 in forum General Tech Discussion
    Last Post: 08-13-2009, 07:42 AM
  5. ZZP Alternator Rewire
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2008, 05:45 PM
