Thread: Stock MAF limitation?
Results 1 to 12 of 12
  1. #1 Stock MAF limitation?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Can't remember or find it. What pulley size/WHP does your stock maf get maxxed out and require you to run a ls1/lq4 style maf or scaler?
    Current mods in sig (the bonnie... have to specify which 3800 sc car I have bc I'm nuts..) and its about to get a FSIC and plog/dp or headers and hopefully around a 3.0-3.2 pulley.
    Feel free to yell at me if I didn't search enough and was lazy.. :-P
    04 GTP -HAI, 1.9 rockers.
  2. #2 Re: Stock MAF limitation?
    Like 11,500hz is the max.
    I don't think you need a larger maf with only going to a 3.2. But you'd have to run it and see if you are going to outlfow the MAF sensor.
  3. #3 Re: Stock MAF limitation?
    Aug 2013
    Sandy, UT
    Hm Ok. Can you view that with tq? I know right now I'm hitting around 250-280 g/s on the maf with a dial on the torque app, I'll have to change it so i can see if i can see freq.
  4. #4 Re: Stock MAF limitation?
    Florida
    I believe you can view it with the torque app, havent messed with it in ages though.
    You'll be fine on a stock MAF with the 3.2/3.0 any smaller and you'll want to start looking for other options.
    Running the mods in my sig, MAF still has some ceiling room
  5. #5 Re: Stock MAF limitation?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Add custom PID with torque to read it in hz.
    PID HEX 221250
    Min value 0.0
    Max value 11500.0
    Scale factor x1
    Unit type hrz
    Equation ((A<8) + B)/2.048
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  6. #6 Re: Stock MAF limitation?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by WolvesSoulZ View Post
    PID HEX 221250
    Min value 0.0
    Max value 11500.0
    Scale factor x1
    Unit type hrz
  7. #7 Re: Stock MAF limitation?
    Aug 2013
    Sandy, UT
    Thanks! Also, theoretically speaking if someone had a ported gen 3 on a top swap and were to instal an fsic before any exhaust mods... Could they run smaller than a 3.4 or is that already pushing it? You know... Hypothetically.
  8. #8 Re: Stock MAF limitation?
    Aug 2013
    Sandy, UT
    And yes I scan for KR regularly
  9. #9 Re: Stock MAF limitation?
    May 2012
    Where winter never ends
    I ran out on the 2.8 Ty. 11500 KZ IRRC'
    EDIT: Maybe it was a 3.0
    2000 Regal - Winter Beater
  10. #10 Re: Stock MAF limitation?
    Aug 2013
    Sandy, UT
    Aaron if your maf read to 11500 kHz (11500000 hz) it's magic
  11. #11 Re: Stock MAF limitation?
    May 2012
    Lol I had major issues when I maxed it out!
  12. #12 Re: Stock MAF limitation?
    hangover park IL
    stock 99+ in a 4" pvc pipe coupler (106mm maf) is only to mid 10khz on a 2.3L whipple with a 3" pulley
    ~James~ Psychotic Gearhead
  1. Replies: 3
    Last Post: 08-05-2013, 04:38 PM
  2. Replies: 1
    Last Post: 04-10-2013, 07:19 PM
