Thread: I need the fuel pros in here!!
Results 1 to 8 of 8
  1. #1 I need the fuel pros in here!!
    GTP Level Member
    Sep 2011
    Motown
    Alright so Im going through this dispute of what injector size I should go with. Should I go with the 42s or the 60s? Now I will have a forced induction set up. At the moment I dont plan on running e85. For now I just plan on getting the car running decently. Once things settle in I will plan to swap to e85. Now my question is can I run 60s with 91 octane and use the 60s at a lower percentage? Or is there a specific operating range for the the injectors.
    Thanks in advance!
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #2 Re: I need the fuel pros in here!!
    I'd just run 60's, to make it easy.
    You can run them at 50%, they wouldnt even care and then when you switch to E85 it might bump up another 20-30%.
  3. #3 Re: I need the fuel pros in here!!
    GTP Level Member
    Sep 2011
    Motown
    It wouldnt "hurt" the injector to run it at a lower percentage? Reason I ask is cause just about everything has an operating range lol
  4. #4 Re: I need the fuel pros in here!!
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Definitely go with 60s in my opinion. I ran 60s both on pump gas on a low power build as well as on E85 now. You shouldn't have any issues with idling/drivability/etc. On pump gas with the 60s. And then they'll be great to have with plenty of headroom when switching to E85!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  5. #5 Re: I need the fuel pros in here!!
    Nov 2011
    NY
    Quote Originally Posted by Classy Pontiac View Post
    Dispute with who? You can use whatever size, its all relative to whether or not it gives an advantage or is needed.
    42's are just a slight bit larger than stock, not running E85 then why do you think you need larger injectors to run decently?
    you can run 60's if you want, adjust the tune!
    range is specific to the injector, look up the specs and you'll know.
    research, research, research, there's plenty of threads on injectors, e85, etc., HPT site too... Ultimately, you leave out some information ie, forced induction? Plans? Mod's? Lol...
    60's won't hurt a thing except the pocket!
    Thanks in advance!
    No problem : )
  6. #6 Re: I need the fuel pros in here!!
    Apr 2011
    Tally, FL
    Just to let u know i was around 12-13ms at wot with a 3.8 pulley, 65's, and raceatronix pump i think injectors max out 22ms.
  7. #7 Re: I need the fuel pros in here!!
    Arizona
    Golden rule is never exceed 80% duty cycle..
  8. #8 Re: I need the fuel pros in here!!
    GTP Level Member
    Sep 2011
    Motown
    Quote Originally Posted by DoubleBlown View Post
    Oh sweet jesus, lots of fuel.
    Quote Originally Posted by 91parkave View Post
    Aye aye captain!
  1. Caspers Fuel Pump Hotwire Kit... Pros/Cons
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 06-09-2013, 02:13 PM
  2. PCM advice need please all you pros :)
    By NAC in forum PCM Tuning
    Last Post: 08-06-2012, 10:40 PM
  3. Pros and cons of GTP??
    By up in boost in forum Off Topic Discussion
    Last Post: 01-14-2010, 02:23 PM
  4. pros and cons
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 11:19 PM
  5. A Little Help from you Pros.
    By Scott B in forum General Tech Discussion
    Last Post: 05-13-2008, 08:31 PM
