Thread: ac compressor leaking? (pic)
Results 1 to 20 of 26
  1. #1 ac compressor leaking? (pic)
    Oct 2013
    WI
    I have a serious leak in my AC system - I fill it and it works fine for a day or two and then stops cooling. Put some dye in it and I believe I followed the whole system under the hood at least, only see some dye on the side of the compressor. Not very much, though. Tried to take a picture, wasn't easy - can see it along the band, and the round thing behind it. Does this seem like the cause of a major leak? I think I got more dye near the low pressure fitting taking it off then I see on the compressor. I see kits on eBay for about $150 for a new compressor, accumulator, and orifice tube. Cheap r134a vacuum pump from harbor freight. This what I'm probably looking at -any kind of leak requires changing everything?
    http://www.merlinsoftware.com/filestore/ac.jpg
  2. #2 Re: ac compressor leaking? (pic)
    Looks to be leaking. Swap the compressor vacuum the system refill and enjoy
  3. #3 Re: ac compressor leaking? (pic)
    Buffalo
    Rockauto has an OEM Delphi compressor , orifice tube and AC delco drier for about $215 shipped
    those ebay bay compressors suck - they fail and or won't fit through the side of the car without lowering the cradle.
  4. #4 Re: ac compressor leaking? (pic)
    Oct 2013
    WI
    Thanks for the responses - thought a knock off would be better then a used one, sounds like maybe not. More than I wanted to spend, but probably worth it. So the $5 orifice tube is fine over the $13 ac delco one? Probably want the $7 o-ring set?
  5. #5 Re: ac compressor leaking? (pic)
    Buffalo
    The delphi compressor comes with the 2 o-rings that you need to attach the line set to the compressor.
    The AC delco drier comes with o-rings as well
    the orifice tube I bought from advance auto parts and used a code Paid $4.
    If your car is a 99 or newer , the orifice tube has a weird crushed plastic end. The new versions sold at the part stores use an actual screen now.
    I also picked up a bottle of PAG 150 oil.
    You will want to want to empty your compressor oil and the compressor oil in the new unit into 2 measuring cups.
    then follow the instructions included with the new compressor. It will tell you how much to add back into the new compressor.
  6. #6 Re: ac compressor leaking? (pic)
    Oct 2013
    WI
    Quote Originally Posted by crazyguy03 View Post
    Have everything on the way, can you please clarify this:
    Are you saying to empty out any oil in the old compressor and any that comes in the new? Do I need to offset the system by what I find in the old one?
  7. #7 Re: ac compressor leaking? (pic)
    Topeka, KS
    I need to replace my compressor as well. I had the same issue the op had but I've put off replacing it for 3 summers now. My brother actually bought me a compressor for Christmas from Napa. But you are saying to empty the new compressor then refill?
    Sent from my SCH-I545 using Tapatalk
  8. #8 Re: ac compressor leaking? (pic)
    Buffalo
    These instructions are actually included with the new delphi compressor. It's a very simple procedure.
    They basically want to make sure you compensate for any oil remaining in the system or removed from it.
  9. #9 Re: ac compressor leaking? (pic)
    Topeka, KS
    Ah. I'll have to look at my instructions. I'm sure after my system has set leaked out but still intact for 2-3 years that some of it has evaporated or leaked out.
  10. #10 Re: ac compressor leaking? (pic)
    Buffalo
    If you guys were closer, I'd have you up and running in a few hours
    PM me any questions
  11. #11 Re: ac compressor leaking? (pic)
    Oct 2013
    WI
    Thanks - I hope to install it this Sunday, I'll need to go out of town to have access to an air compressor so I want to make sure I have everything I need and know what I'm doing.
    I was looking at the orifice tube today and it's a bit worrying, I can't bleed the brakes and I'm nervous about damaged a brake line just moving it aside. I saw in another thread someone said they used a 26mm crow's foot wrench. I was looking at it and it seems like at least from the front it's tight going through the lines on the abs module, never used a crow's foot but I assume it wobbles a bit. Maybe can do something from the side. I just about had a crescent wrench on it that way, which the handle under the boost. Not sure if I could actually get an torque. Worse comes to worse with my situation being a leaking compressor the tube may be okay? Last two cans I ran through did have leak stop, not sure if that gums stuff up.
    One other question, won't get my compressor until tomorrow so this may be clarified but it sounds like you need 525 mineral oil for the o-rings. Some people say just use the pag150 oil, others say it attracts moisture. Only mineral oil I see online in parts stores if just labeled "r12" for doing r134a retrofits. Is 525 mineral oil special or can you just get generic stuff from walmart?
  12. #12 Re: ac compressor leaking? (pic)
    Buffalo
    You will need a set of hvac gauges , a vacuum pump and way to recharge.
    The orifice tube is a must. So is the drier
    remove or move out of the way the everything on the driver side of the car under the hood
    cruise control, strut tower bar, air intake and box, abs module and brake fluid reservoir
    with the car raised , the driver side tire should be low enough to allow you inside the wheel well
    Remove 2 10mm nuts and 1 bolt.
    Inside remove the 2 15mm nuts on the brake fluid reservoir
    this will allow room for the abs module to move enough to access the union on the AC line.
    Depending on time, I once removed the line from the car all together. 1 bolt on the fire wall and another union that connects the line to the condensor core. This allowed a lot more room for me to remove the union on the line to access the orifice tube.
    A cheap set of picks from harbor freight comes in handy
    i used pag150 Are there better oils? Maybe. But this was what i been using so far
    also you have to install a new stud on the compressor. Make it hand tight at first. Then find a nut large enough to fit over the stud. Then put the correct size nut ontop of that and tighten all the way down. Then remove both nuts. This will seat the stud.
    If you don't seat the stud properly , you will not get a proper seal on the line manifold and it will leak.
    This is is a breif of the top of my head posting from my phone how-to
    Hope it helps
  13. #13 Re: ac compressor leaking? (pic)
    Oct 2013
    WI
    Hope it helps
    Thanks - I did order a drier and the tube with compressor. Bought a pump and gauges as well - have another car that will need to be replaced as well so they'll get some more use, and no parts stores had them to lend.
    I'll see what I can do with the tube, probably will be fine. Just don't want to kink or break a line while I'm out of town on a sunday and end up stranded
    So you used the pag 150 oil on the o-rings instead of mineral oil?
    Didn't see anything about the stud before, I may have follow up with you on that when I get the compressor, definitely want to have that ahead of time. Or maybe the instructions will have specs on thread/length/etc?
  14. #14 Re: ac compressor leaking? (pic)
    Buffalo
    http://www.rockauto.com/info/Delphi/H6inst.pdf
    I was able to turn the compressor by hand before install. Don't worry about that part
  15. #15 Re: ac compressor leaking? (pic)
    Buffalo
    It's included. But I had to repair someone else's mistake of improperly installing it
    so to avoid any possible issue just make sure it's seated well
  16. #16 Re: ac compressor leaking? (pic)
    Oct 2013
    WI
    Got the pump today, can turn it by hand.
    A note if anyone stumbles on this thread regarding o-ring oil, I found another post saying using "r12" mineral oil, found some at Napa for half the price GM wants, about the same viscosity 515 vs 525
  17. #17 Re: ac compressor leaking? (pic)
    Buffalo
    I honestly never had an issue with the o-rings
    all the info I provided for you is exactly how it's been done for years here and at work
  18. #18 Re: ac compressor leaking? (pic)
    Oct 2013
    WI
    Now going to do this project tomorrow - another question, how did you take off the compressor. I see official way seems to be taking off pass wheel and fender line, I thought I saw somewhere some did it from the bottom. Would be easier if I could do it that way on ramps
  19. #19 Re: ac compressor leaking? (pic)
    Buffalo
    Remove your passenger wheel. Remove your plastic inner gaurd
    now you can clearly see the compressor. Remove belt, line manifold , electrical connector and all the nuts.
    Should come right out the side
  20. #20 Re: ac compressor leaking? (pic)
    Oct 2013
    WI
    Ok, the aftermath, and a question...
    Compressor was a lot of work, figuring out which bolts were better from the top/bottom/finding the right extensions. And a took a while to get it out, keep getting hung up, then it just came right out. New one went right back in. The green o-rings that came with the delco accumulator were skinnier and a little bigger, so I re-used the old ones. I didn't end up changing the tube, was a long day. Decided since the oil came out of the old compressor was clean, and we cut open the old accumulator and it was clean, the bags of moisture absorber were intact. Sound like an ok call?
    The big question ... was using manifold gauges to charge it back up, first can went in fine - could see it in the inspection glass. Second can, nothing. Can seemed to be fine, tried another using just the charge hose connected directly to the low port, nothing. Tried using the blue line, nothing. The only thing I couldn't really change was the quick connector to the fill port. Thinking of getting another can and using a cheap included hose. Checking pressure will make sure I don't overfill? I assume only one can made it in. AC was working fine, was a little cooler on the pass side, but I think that's normal when you have a low charge - probably only has 12oz. Any thoughts?
  1. Buying time...Leaking AC compressor...Solution
    By BrandonHall10 in forum General Tech Discussion
    Last Post: 04-21-2015, 11:01 AM
  2. AC Compressor Keeps Going Out
    By Steven Monteith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2013, 01:36 PM
  3. AC Compressor Leaking
    By Scott Kane in forum General Tech Discussion
    Last Post: 12-10-2010, 12:02 AM
  4. A/C Compressor Leaking
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 11:32 PM
