follow the plastic hard lines around the engine, they make a loop basically. fpr, under the snout, the bbv, the evap from the TB. all over.
not sure the volts at the pig tails. there are threads with that info. if you see missing insulation or cracks in the wires, theres no need to check the volts, the wires are bad.
