Thread: Boost Gauge Stopped Working
Results 1 to 6 of 6
  1. #1 Boost Gauge Stopped Working
    Aug 2008
    New Jersey
    On the little computer in the 97' to 03' Grand Prix GTP's, there is a boost gauge. Mine stopped working? Anyone know how to fix this?
  2. #2 Re: Boost Gauge Stopped Working
    Feb 2008
    Have you made sure that the belt hasn't slipped off the S/C? That is were I would start.
    The next thing I would look at is the BBV.
  3. #3 Re: Boost Gauge Stopped Working
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    Is the bulb in it burnt out? have you checked to see if the map was dead?
    Engineering the impossible.
  4. #4 Re: Boost Gauge Stopped Working
    PA
    The display in the DIC is a digital display, and just backlit by bulbs. So the entire screen would be out, not just the boost gauge.
    Couple things to check would be the MAP sensor and the boost bypass valve for correct operation.
    2001 GSE
  5. #5 Re: Boost Gauge Stopped Working
    May 2008
    Broken Arrow, OK
    Quote Originally Posted by Zef_66 View Post
    If its lit by bulbs then it may be segmented in the back. Ive never opened one up so i dont know what it looks like.
    Just throwing some ideas out there.
  6. #6 Re: Boost Gauge Stopped Working
    PA
    Quote Originally Posted by Merlin View Post
    I just had mine apart. It is segmented. But think about how the boost gauge works. Do you really think there is 6 separate bulbs for each boost bar?
    Let me tell you, there isn't
    2001 GSE
  1. Working on a digital gauge cluster project...
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 09-22-2009, 02:53 PM
  2. Boost and oil pressure Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:40 AM
  3. Boost gauge on 03 gtp
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:06 PM
  4. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
  5. HUD Stopped Working After Huge Speed Bump
    By AmericaFcukYeah in forum General Tech Discussion
    Last Post: 05-24-2008, 12:13 PM
