Thread: Windshield washer, Passenger window, and p0401 p0121 codes.
Results 1 to 10 of 10
  1. #1 Windshield washer, Passenger window, and p0401 p0121 codes.
    SE Level Member TwoFoolsAMinute's Avatar
    Apr 2014
    Iowa
    2000 GTP coupe
    Windshield washer does not work. I push the tab and nothing happens. No noise. No spray. Washer fluid reservoir is full.
    Passenger window works just fine most of the time. On very rare occasions it just doesn't work at all. The next time I drive it works again.
    p0401 Insufficient EGR Flow. The obvious thing is that the EGR is bad...but I've read here that often this code is given if MAP sensor is bad.
    P0121 Throttle Position Sensor. So, just replace the TPS, or should I try something else first?
    Extra symptoms:
    Boost indicator on DIC only goes about half boost where it once went full.
    last night the car died twice slowly taking off from idol in the drive-thru.
    What say you?
  2. #2 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    St. Louis
    Washer pump is probably toast. Does the passenger window work on the pass. side and not always on the drivers side? Could just be a dirty drivers side switch.
  3. #3 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    Apr 2014
    Iowa
    Quote Originally Posted by FordMan77 View Post
    Neither switch will work.
  4. #4 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    Quote Originally Posted by TwoFoolsAMinute View Post
    If you read up on what this code, you'll understand that it might have nothing to do with the EGR. Hence why you found posts (likely from me) suggesting a bad MAP sensor. See... here's how this works. The pcm tells the egr to open and then it watches for a pressure change. When it doesn't see a pressure change..it says "YO!!!! I'm not seeing the flow from the EGR opening". It's a bad assumption that the EGR is bad because it's name is in the code title.
    Washer.. test for power and ground at the pump.
    TPS.. if you have a real time scanner..watch throttle %
    Boost.. yeah..car is pissy, likely TPS pissy
    Stalling.. you did say you have a TPS issue, right?
  5. #5 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    Also, as a side note regarding the washer pump. If it is determined the pump needs replaced, it is very easy to pull the passenger side headlight assembly and go through there. If I can get my gorilla sized arms into it.....anyone can.
    Official GPF Red Neck
  6. #6 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    Apr 2014
    Iowa
    I'm attempting to replace the TPS. It looked simple enough, but I can't get to the lower screw because the upper radiator hose connection is in the way. How should I deal with this?
  7. #7 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    Apr 2014
    Iowa
    Ok, through trial and error, I got the TPS replaced. The thing shifts correctly, goes fast, and does not stall now. Still, there are no bars showing on the boost indicator on the DIC. Is this a MAP sensor problem?
  8. #8 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    Kemmerer, Wyoming
    did you ever figure out why it was only showing half boost? I have an engine code P0401 and I am only getting 4-5 lbs of boost, before I was getting 9-10.
  9. #9 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    Apr 2014
    Iowa
    Everything was a vacuum leak. $.99 worth of vacuum hose fixed my engine problems.
  10. #10 Re: Windshield washer, Passenger window, and p0401 p0121 codes.
    Kemmerer, Wyoming
    I've replaced all my vacuum line's, I'm going to try a map sensor
  1. 98 GTP windshield washer
    By paddenjoseph in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2013, 10:12 AM
  2. Windshield washer nozzle???
    By mick777wauchope in forum General Tech Discussion
    Last Post: 04-16-2012, 03:06 PM
  3. Windshield washer fluid
    By flyboyray1 in forum General Tech Discussion
    Last Post: 03-18-2010, 10:07 PM
  4. Windshield Washer Fluid
    By Pontiac99GTP in forum General Tech Discussion
    Last Post: 09-09-2009, 01:35 AM
  5. Runs bad, won't start...Codes P0401 & P0452
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2008, 06:55 PM
