Thread: Car shuts off while cruising
Results 1 to 20 of 23
  1. #1 Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    I have a 05 Grand Prix car seems to shut off while cruising not sure what it is just replace the crankshaft sensor because I thought that was the problem seems to happen once the car gets warmed up once it stalls will not start up until the car has cooled off does anyone know what it could be there are no codes being thrown
  2. #2 Re: Car shuts off while cruising
    St. Louis
    Could be the ICM. Need to verify what you're missing when it shuts down. Spark or fuel.
  3. #3 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    Notice rpm started to raises about 500 rpm then drop back down a cpl of times before it shut off
  4. #4 Re: Car shuts off while cruising
    So you took the balancer off and replaced that sensor right??
  5. #5 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    Yes with a stupid bwd from advanced checy wanted 120 for a ac delco crank sensor thinking maybe bwd product is getting heat soaked? Cheap product?
  6. #6 Re: Car shuts off while cruising
    next time it stalls out, check for spark by removing a plug wire off the coil and resting it so its a inch over the coil where it sits and so you can see it while you crank the engine, see if a spark jumps.
    you can also see if you got fuel pressure but pushing the pin in the shrader valve on the fuel rail, watch your eyes it will spray out if its got pressure. nothing will come out of its got no pressure.
  7. #7 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    So all three coils getting spark once car dies I take it icm is good possibly the bwd brand is junk and overheating or could it be a bad camshaft sensor?
  8. #8 Re: Car shuts off while cruising
    got fuel pressure?
  9. #9 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    Yea of course once car cools it starts right up till engine gets hot and stalls
  10. #10 Re: Car shuts off while cruising
    after it stalls is there gas shooting out the shrader valve when depressed? yes or no?
    fuel pumps pull this crap.
  11. #11 Re: Car shuts off while cruising
    Enfield, CT
    In my experience in several shops, borg warner is sh!t overall and when it comes to crank sensors on these cars, nothing seems to be a good as an OEM one. You could try a delphi one and also rockauto has great deals on delco stuff too.
  12. #12 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    Yea gas shoots out of shrader my fuel pump is three months old aem e85 pump
  13. #13 Re: Car shuts off while cruising
    gardner,mass
    Ok so your modded then.... Im guessing you might be to rich in your lower maf table.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  14. #14 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    If I was too rich why would it cause car to shut off like something is getting heat soAked car runs when its cool but second warms up rpms flutter and car stalls with no starting until car is cool again
  15. #15 Re: Car shuts off while cruising
    gardner,mass
    My car did the exact same thing when i tried combatting kr by adjusting fuel in the lower hz table instead of removing timing.
    Colder air is denser so your running more lean until it warms up then its to rich and floods itself out.
  16. #16 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    Really thats odd same symptoms as mine?
  17. #17 Re: Car shuts off while cruising
    gardner,mass
    Quote Originally Posted by kurupt305 View Post
    Exactly and i couldnt figure it out. Tried changing pump with no change and noticed the more fuel i added in the lower rpms the worse it got so i change my sub 7000 hz table to stock and it went away.
  18. #18 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    Well swapped out my crank sensor becauseni thought it was bad with an ac delco one and now car wont start has that happenedn to anyone before?
  19. #19 Re: Car shuts off while cruising
    double check the wire harness to the crank sensor up to the icm. make sure its all plugged in.
  20. #20 Re: Car shuts off while cruising
    Jun 2013
    Hollywood ,FL
    Well the harness to crank sensor is connectedill disconnect it and try to connect it
  1. 2006 GP cruising along and then stalls
    By juicestain100 in forum General Tech Discussion
    Last Post: 10-24-2014, 05:50 AM
  2. Throttle dip while cruising.
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2014, 07:42 PM
  3. Highway Cruising
    By JDCMoney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-20-2009, 03:31 PM
  4. kr at cruising???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:20 AM
  5. Few kills just cruising around..
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 11-02-2008, 10:20 PM
