Thread: getting some knock starting around 4800 rpm.. any suggestions?
Results 1 to 16 of 16
  1. #1 Re: getting some knock starting around 4800 rpm.. any suggestions?
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Quote Originally Posted by 97AutoXVette View Post
    Hmm, that's interesting.. How does the IC play an effect into the equation outside of normal inlet air temp cooling? I was under the impression that I wouldn't need an intercooler as soon with running E85 since the added fuel can take excess heat out of the air. Appreciate any more info you have on that end.
    AFR is pretty conservative and around 7/1 to 8/1 anytime the engine is under load/boost (down to around 7/1 @ WOT).
    I think what it boils down too is E-85 quality. It 87 mixed with ethanol. Perhaps other states use higher quality base fuel to mix with ethanol. I'm in Canada and the E-85 in my region wasn't impressive.
    It was about equivalent to 100 octane gasoline at best. AV gas alone at 104-108 octane was far superior.
    But I was running 2.6 pulley with the worst possible set up for KR. Just so you know Ethanol although very high octane, the threshold for knock resistance in some situations is much lower than Leaded race fuel. Leaded race fuel tolerates leaner mixtures a lot more than Ethanol. Also leaded fuel tolerate higher intake temps than E-85. E98 or pure Ethanol is another story. The little bit of cheap unleaded fuel is what causes the knock.
    So you could be too lean at the moment. Way too rich can cause rich knock as well. You need to provide A/F ratio data.
    In your case with the 3.5 and your mods you should never see any knock. What's your A/F ratio I don't think you answered this yet ?
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  2. #2 Re: getting some knock starting around 4800 rpm.. any suggestions?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by TwinV6GTP View Post
    A/F values (on my Wideband tuned for pump gas) are 14.7 @ cruise (target 9.85 on E85).
    @ 28% throttle, it adds 1 to the A/F values, which yields between 12.5 and 13 on my WB.
    after 45% throttle, full PE targets kick in which are set to 8/1. That yields around 10.8 - 11.0 AFR values on my wideband. I originally targeted 7.3 AFR values as base PE, but was seeing my wideband values of 10.0 - 10.3 during WOT, which seems too rich considering that is sub 7 AFRs on E85.
    Let me know if all that made sense!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. knock
    By 04BlackComp_G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2011, 12:27 AM
  3. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  4. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
