Thread: I think my fan blower is gone (AC and Heat not coming through)
Results 1 to 8 of 8
  1. #1 I think my fan blower is gone (AC and Heat not coming through)
    Jul 2010
    Canada
    My AC and Heat started to go, whenever I went over a bump it kicked in. It has finally stopped all together though. I believe I need to replace the blower and motor assembly. Is this an easy task? How long should it take?
    I checked the fused but their the big square fuses and I am unsure on how to check to see if those are blown.
    Any help would be appreciated.
  2. #2 Re: I think my fan blower is gone (AC and Heat not coming through)
    Feb 2013
    37.295091, -121.930053
    that big square fuse is called a relay . i bet that blew on ya
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: I think my fan blower is gone (AC and Heat not coming through)
    There's a fuse that feeds the relay.
    When you say your heat and ac go... do you mean there is no air coming out the vents or you don't feel the temperature you expect?
  4. #4 Re: I think my fan blower is gone (AC and Heat not coming through)
    Jul 2010
    Canada
    There is only a small amount of air coming out, not enough to cool the car, the air is cold but not blowing through like it used to. Changing the strength of air does nothing
  5. #5 Re: I think my fan blower is gone (AC and Heat not coming through)
    GT Level Member 05CompG's Avatar
    Arizona
    Also check the connector that is behind the dash (big rectangle one) that connecets the HVAC controls. I had this same issue and went thru countless dollars and a full summer w/o air thinking it was fuses, relays, and the blower motor only to find out that the whole connection melted inside and the wires were shorting out.
    Her Name...Stacii Dash
  6. #6 Re: I think my fan blower is gone (AC and Heat not coming through)
    Jul 2010
    Canada
    05CompG
    How did you fix your issue? Did you have to get all new wiring?
  7. #7 Re: I think my fan blower is gone (AC and Heat not coming through)
    Arizona
    Yeah i went to a JY and cut the whole connector out of a donor and spliced it into my own. I still gotta go back and solder it all but i jus did some surgery with liquid and regular electrical tape.
  8. #8 Re: I think my fan blower is gone (AC and Heat not coming through)
    Dec 2012
    Where 4T65E's were born
    So.. The blower stays the same speed regardless of the blower selection? Audibly from the blower motor or feeling the air coming from the vents?
    Sold.
  1. No heat or A/C blower
    By bwaaso in forum General Tech Discussion
    Last Post: 05-12-2012, 07:30 PM
  2. Replies: 3
    Last Post: 02-15-2012, 05:23 PM
  3. no heat coming out of heater
    By jharry83 in forum General Tech Discussion
    Last Post: 03-19-2011, 09:57 AM
  4. Blower/Heat
    By DavePA in forum General Tech Discussion
    Last Post: 11-21-2010, 02:16 PM
  5. no a/c, no heat, no blower, key stuck
    By problems in forum General Tech Discussion
    Last Post: 08-28-2010, 07:55 PM
