Thread: Am I CRAZY?!? Gas gauge weirdness...
Results 1 to 20 of 38
  1. #1 Am I CRAZY?!? Gas gauge weirdness...
    Donating Users
    USA
    Help me out here if you can please!
    What I've been seeing on my 98 GT's gas gauge has been giving me fits. For example: I'll drive on the highway for an hour and the gas gauge doesn't move a bit. I'll think, "Great! Excellent highway mpg!" Then it will suddenly "break loose," and when it does it's like it fell off a cliff. :P Another one: I was driving down a hill at about 45 mph, and had to make a really sharp turn to the left, and when I made the corner the gauge needle moved down about 1/8 of a tank from where it was, and stayed there! Now, unless my car is an absolute gas hog, I can't see it eating up 1/8 of a tank of fuel just going around ONE corner! But... it never came back up! :(
    After searching around a bit, I think my problem might be the sending unit/float arm of the fuel pump sensor. Maybe.
    Does that sound about right... or am I really crazy?!? Yowza!!! :P
    Black 1998 GT Coupe
  2. #2 Re: Am I CRAZY?!? Gas gauge weirdness...
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    Nah......the gas gauges on these cars are typical odd. These cars came with a 18 gallon tank. My gas gauge responds as if it were a 12 gallon tank. At half tank, its a fight to put 6 gallons in it. I even replaced the pump and sending unit. No change. I dunno if this is due to the gauges were just off from the factory or if there is a voltage break down due to age.
    Official GPF Red Neck
  3. #3 Re: Am I CRAZY?!? Gas gauge weirdness...
    Dec 2012
    Where 4T65E's were born
    Mine is a little off but not too drastic. It will go a couple lines higher or lower depending on the driving I'm doing. Stopping and accelerating it will always go down but when sitting at a light I can watch it slowly go back up a line or two. I'd consider that normal. If it;s really jumping around like from 1/4 to a half then replacing the sending unit would not be a bad idea, our impala's gauge would go from full to empty randomly which was the sending unit.
    Sold.
  4. #4 Re: Am I CRAZY?!? Gas gauge weirdness...
    Jan 2014
    AR
    I caught my 99 GTP doing a little of this the other day. Twice in a short period of time, actually. I figured its that $20 sender on the pump. But the issue has not occurred again in the several weeks since that happened, and I've been watching for it.
  5. #5 Re: Am I CRAZY?!? Gas gauge weirdness...
    Donating Users
    USA
    Thank you! I feel a little less crazy now! :)
    Black 1998 GT Coupe
  6. #6 Re: Am I CRAZY?!? Gas gauge weirdness...
    GT Level Member mainecrab's Avatar
    Feb 2008
    I go by the gallons used now instead the gas gauge. If you wanna see your real MPG may wanna get a OBD II bluetooth or other and use like Dash application on android to read this in real time.
  7. #7 Re: Am I CRAZY?!? Gas gauge weirdness...
    if you really want to see your true mpg, do it the old way,
    write your miles down, or set the trip, fill the tank till the pump clicks off the first time. drive the car till its low again, now fill it up the same way at the same station if possible. now divide the gallons you just put in the car and miles you have driven.
    its the only true way to log your mpg avg and be 100% sure. oh, and its free lol
  8. #8 Re: Am I CRAZY?!? Gas gauge weirdness...
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by michaelb721 View Post
    You should see mine, always reads full. Untill you park then it drops to E. Shake the car and it jumps back up to full. Im be running on no gauge just DIC gallons used for about 2 years now. Cant be bothered to replace the level sensor because it will probably piss the pump off and it cost me a new pump.
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: Am I CRAZY?!? Gas gauge weirdness...
    wussey ^^^^^^ i revoke your brother status lol its a 20 dollar fix. pump dont know wtf is going on...its a inanimate object lol
  10. #10 Re: Am I CRAZY?!? Gas gauge weirdness...
    Apr 2012
    Dayton, OH
    Noooooo, give it back. Its not I swear my car has feelings. Like when I replaced the speakers and broke the rear springs. The car is angry that im fixing its problems. Main reason I haven't touched the plugs, fuel level sensor, fuel filter, LIM or UIM gaskets. Im afraid of what its capable of.
    2012 F150 STX
  11. #11 Re: Am I CRAZY?!? Gas gauge weirdness...
    Feb 2013
    37.295091, -121.930053
    Kyle your such a whimp. It took me about 2 hrs to install a new pump. And my gas gauge works just like the old one because I used the old float.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  12. #12 Re: Am I CRAZY?!? Gas gauge weirdness...
    revoked!!!!!!!! lol fix that stuff. cars beak down, get used to it, unless your the reason it breaks when you try to fix it.
  13. #13 Re: Am I CRAZY?!? Gas gauge weirdness...
    Apr 2012
    Dayton, OH
    No comment
    2012 F150 STX
  14. #14 Re: Am I CRAZY?!? Gas gauge weirdness...
    nuff said lol
  15. #15 Re: Am I CRAZY?!? Gas gauge weirdness...
    Donating Users
    USA
    The $20 part that was mentioned interests me... got a part number to go with that? Hint, hint. :)
    Black 1998 GT Coupe
  16. #16 Re: Am I CRAZY?!? Gas gauge weirdness...
    Apr 2012
    Dayton, OH
    DORMAN Part # 911008 iirc look it up on RA to confirm
    2012 F150 STX
  17. #17 Re: Am I CRAZY?!? Gas gauge weirdness...
    so you know what to get but just wont change it lol even worse.......
  18. #18 Re: Am I CRAZY?!? Gas gauge weirdness...
    Jan 2014
    AR
    Well now comes the part where I'm crazy. I must have got mixed up because it ain't $20 now. Add a hundred. But they send you two senders, from the look of this site:
    http://www.rockauto.com/catalog/more...318&cc=1357141
    I think one day me and my friend had my fuel pump out and I asked about that so he pointed at the white plastic sensor and said it was a twenty dollar item. My bad. Thought I had surfed it up and confirmed that shortly thereafter. Good info one day is bad info the next. At least if I can't do anything about your car's feelings I can let you know you're not alone so maybe you'll feel less crazy.
    I'd never rely on the tank / pipe to "top off" at exactly the same "fullness" each time. Shutoff sensitivity at individual gas pumps varies wildly in my opinion.
  19. #19 Re: Am I CRAZY?!? Gas gauge weirdness...
    Apr 2012
    Dayton, OH
    Whats even worse is I have my RA/Orileys/AAP/AZ cart full of stuff I need to replace.
    2012 F150 STX
  20. #20 Re: Am I CRAZY?!? Gas gauge weirdness...
    Apr 2012
    Dayton, OH
    Quote Originally Posted by idrivejunk View Post
    The dorman one is a lot cheaper I just heard that the gasket might be too big and you have to re use your old one or buy one from the dealership.
    Remeber if you use Rockauto to google for the 5% off coupon code
    2012 F150 STX
  1. Fuel Gauge acting crazy
    By 2000GrandPrixGT2000 in forum General Tech Discussion
    Last Post: 03-03-2013, 04:20 PM
  2. More weirdness......
    By Truckin2001 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2012, 06:42 AM
  3. PRNDL Weirdness
    By jeepers in forum General Grand Prix Discussion
    Last Post: 01-22-2012, 10:09 AM
  4. crazy gas gauge
    By kris in forum The Rant Forum
    Last Post: 09-04-2009, 02:17 AM
  5. oil psi gauge going crazy?
    By Bio248 in forum Off Topic Discussion
    Last Post: 02-02-2008, 06:15 PM
