id just stick with the SD's for the cost if nothing else.
you dont have to do a thing to them, but most will change out the flex pipe to a better one. removing the that dumb drain trap in the dp is easy to get done too. you could make all your cuts with a sawsall and have it welded up.
Is the drain pipe worth getting rid of? Cause I'm trying to not have to do any or not very much fabrication
