Thread: Idle issue on startup the good after 20 to 30 seconds ??
Results 1 to 7 of 7
  1. #1 Idle issue on startup the good after 20 to 30 seconds ??
    Donating Users Uno99's Avatar
    Appleton, Wi
    My 2002 GTP has been acting squirrely lately.
    The car starts then as soon as you hear the loud sucking from the CAI it starts to stumble. I can keep it running if I work the throttle a bit then after 20 to 30 seconds when the loud sucking from the CAI stops it will idle and run just fine.
    I replaced the IAC valve, fuel pump, fuel filter, plugs, wires, added a caspers hotwire kit.
    No Codes
    Ive tried unplugging the maf but it will not stay running.
    Thoughts? Ideas? Thanks guys
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  2. #2 Re: Idle issue on startup the good after 20 to 30 seconds ??
    dirty TB? bad fpr?
  3. #3 Re: Idle issue on startup the good after 20 to 30 seconds ??
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    Mine did that when I first put mine on, it was from the maf. I tried unplugging it to see if it would run that way and it didn't make a difference but I ran out of things to try and just replaced it, after that it ran fine.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  4. #4 Re: Idle issue on startup the good after 20 to 30 seconds ??
    The sound is from the air rushing past the IAC passage inside the throttle body.
    Perhaps the IAC is opening too much and killing it out.
  5. #5 Re: Idle issue on startup the good after 20 to 30 seconds ??
    Appleton, Wi
    I just changed the IAC this evening ugh. It weird that th issue is intermittent and only last 20-30 seconds after startup and happens less when the engine is warm.
  6. #6 Re: Idle issue on startup the good after 20 to 30 seconds ??
    Appleton, Wi
    Still the same after cleanin Maf and TB my wideband goes way lean 17:1 then 18:1 the off the gauge after that.
  7. #7 Re: Idle issue on startup the good after 20 to 30 seconds ??
    Appleton, Wi
    Just wanted to post my solution. There was a gap between battery and terminal. Even tho i had the battery bolt as snug as possible the play between was causing intermittent issues. I simply placed a steel washer inbetween and tightened it up no isssues since
  1. Rough, surging idle at startup
    By MacGyver in forum General Tech Discussion
    Last Post: 05-06-2012, 08:25 AM
  2. Idle issue
    By CASconce in forum General Tech Discussion
    Last Post: 01-16-2012, 08:20 PM
  3. Idle issue
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 10-20-2011, 06:23 AM
  4. Startup issue with the GTP
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-29-2010, 09:53 PM
  5. Car stumbles after startup and has a jumpy idle
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 07:23 PM
