Thread: Car stumbles after startup and has a jumpy idle
Results 1 to 8 of 8
  1. #1 Car stumbles after startup and has a jumpy idle
    SE Level Member Lionel's Avatar
    Moncton N.B.
    After I start my 04 GT I need to give it a shot of gas so it wont stall, i replaced the fuel pump and it didnt dp anything, I haven't replaced the fuel filter yet, could this be causing it? I'm leaning towards the fuel injectors. anyone have this problem?
  2. #2 Re: Car stumbles after startup and has a jumpy idle
    GTP Level Member SuperSport's Avatar
    Michigan
    Remove and clean your throttle body with throttle body cleaner and a toothbrush. That will fix your problem.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Car stumbles after startup and has a jumpy idle
    Moncton N.B.
    is the throttle body what's connected to the air intake? just before it hits the engine?
  4. #4 Re: Car stumbles after startup and has a jumpy idle
    Moncton N.B.
    I have the throttle body in front of me, and all i see is a trap door looking thing, clean on one side and full of carbon on the other, am i supposed to remove the plastic cover on the side and clean up all in there?
  5. #5 Re: Car stumbles after startup and has a jumpy idle
    Jan 1970
    Maquoketa, Iowa
    Check your MAF sensor or clean it. You can unplug it to see if it changes anything in the idle. If you don't notice anything change, there's a good possibility it may need replaced or cleaned. If it does change the idle after it is unplugged, thats not it, check for vac leaks.
  6. #6 Re: Car stumbles after startup and has a jumpy idle
    Wausau, WI
    problem solved?
  7. #7 Re: Car stumbles after startup and has a jumpy idle
    Moncton N.B.
    I changed the oil, flushed the coolant, put in a new fuel filter, cleaned out my throttle body, and yes problem is solved, So it was either the fuel filter or the TB being full of carbon.
    Appreciate the info guys, I'd have never thought to clean out my TB. Kinda new at the whole self repair thing
  8. #8 Re: Car stumbles after startup and has a jumpy idle
    Wausau, WI
    that is what this site is for..........glad it is fixed.
  1. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  2. Bad lag on startup & accelleration
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2009, 03:07 PM
  3. knock at startup
    By Jakegday in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 08:01 AM
  4. oil burn at startup?
    By Golgo13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2008, 07:18 PM
  5. Hard startup and noise
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-31-2008, 04:58 PM
