Pull the vacuum hose off the fuel pressure regulator and check for fuel in that line. There shouldn't be any, but that's the most common issue that causes a backfire. Typically on an NA too.
Since you were welding.. did you unhook the battery? If so.. check that. If not.. maybe on the crankshaft/maf
