What is the advantage of modified rails when extenders cost way less?
Looks cooler.
Extenders are the way to go. Super easy install. Litterally you pop the extenders on, Remove your stock rail studs, Install longer studs, Place 1" spacer on each stud, Bolt rails back on. I highly recommend it.
and what does this do for you? and can it be done on a N/A
Its for running an intercooler under the blower.
Modded rails are needed for a fsic
Short stack intercooler are 1" thick. 1" fuel injector spacers work for them. Short stack intercooler are about 1/4 of the performance of a full size intercooler.
Full size intercoolers are 2-1/4" thick and nobody makes a spacer that tall. Modified full rails or new aluminum fuel rails.
Hey now! The short stack isnt that bad. The temp drop isnt quite as much but they don't heat soak or any other BS people claim.
