Thread: Power steering whine
Results 1 to 4 of 4
  1. #1 Power steering whine
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Ever since I got my 05 gtp on the road the power steering pump has whined. The steering wheel turns easy all the time. I replaced with a reman pump and fluid from the parts house but it's still the same. The fluid out of the old pump was very dark. It will get a little bit quiter after warms up. Do I need to check fluid cold or hot after I drive some. Does it need to be running while I check? Anything else could make it whine like that? And no it's not the supercharger. The cars stock Lol
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Power steering whine
    Check the tranny fluid level while hot, they tend to whine just like the powersteering.
  3. #3 Re: Power steering whine
    stanford Ky
    The trans fluid is good. I just changed it.
    99 gtp- sold
  4. #4 Re: Power steering whine
    St. Louis
    You can check it hot or cold IIRC. At least on my 00 there are marks on the stick for hot and cold readings. When you changed the pump/fluid did you bleed the system or just fill it up and go? Air in the system can make it whine. Went through this on an Imp once. Took 5-6 tries at bleeding it to finally get it to shutup, lol...
  1. power steering whine
    By Orange04CompG in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 11:30 AM
  2. Power Steering whine
    By nickgpgt in forum General Tech Discussion
    Last Post: 05-26-2013, 07:38 PM
  3. power steering whine?
    By Garrett Mofford in forum General Tech Discussion
    Last Post: 10-19-2012, 04:37 PM
  4. power steering whine on turns
    By Warbeaver in forum General Tech Discussion
    Last Post: 06-04-2010, 08:21 AM
  5. Power steering whine on left turns only...
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 12:19 PM
