Thread: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
Results 1 to 20 of 29
  1. #1 Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    1997 GTP 4 Door, ~225k miles
    I noticed coming of the interstate off ramp yesterday at a red light that my car was shaking quite noticeably and emitting a "blub blub blub" noise from the exhaust. As I accelerated from the light, it seemed down on power to me.
    I am uploading a video to Youtube now of the engine running and the sound coming from the exhaust.
    It isn't as noticeable in the video as I had hoped, but maybe you guys can get me started in the right direction.
    I will post the link when (if) it ever finishes uploading.
    Thanks!
  2. #2 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    HUDSON
    Exhaust leak at the resonator will cause that, had it happen the same way almost.
  3. #3 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    Engine Miss?: http://youtu.be/bbbsTMcljX8
    There's the youtube link. Hopefully it helps clear things up.
  4. #4 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Kinda sounds like it down a cylinder.
    Last time you changed plugs and wires?
    I start there and see if it still does it, also your check engine light is one and there is likely a code if not a few. I just assume it was on before this happened and something new is now on there.
  5. #5 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    Yeah, it's still coding for a crankshaft position sensor even though it's been replaced and codes cleared.
  6. #6 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    HUDSON
    Check for exhaust leaks.
  7. #7 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    The harness is likely bad if the code keeps coming up.
  8. #8 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    Update:
    Replaced all the plugs. Very disheartening after such a battle that it didn't solve the problem. (The rear one closest to the driver's side was a real bear!). They were looking kind of rough, so it needed doing anyways I guess. The passenger rear one had a lot of oil on it as well.
    I unplugged all the wires at the coil packs, and they are very corroded. I might want to do coil packs and wires too while I'm at it.
    The check engine light is now flashing, so I might get that read at Autozone tomorrow.
    Also, just for S's and G's I unplugged the IAC with the car running and nothing changed. Same with the MAF. Don't know if that means anything.
    I'm off to bed, defeated for tonight. 14 hour shift starts in 6 hours Hopefully I can limp it to work in the morning.
  9. #9 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Change then plug wires if you havent the cheap lifetime warranty parts store brand works from AZ, AAP, Orielys then clean up the coil packs with some sandpaper and put dielectric grease on them.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  10. #10 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    im thinking clogged cat if new wires and cleaning the coils dont fix it. being you have 225,000 on it.
    flashing cel usually comes back to being a clogged cat, or needing a tune up real bad.
    you can pull the up stream o2 sensor to make a exhaust leak. yes it will sound like crap but if it feels like its getting more power now the cat is clogged up.
    and never unplug a sensor while the car is running. car off unplug them, then fire it back up. this really only works for the maf to see if its not working well too.
  11. #11 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    Ok, I'll try new wires and cleaning the coil terminals tonight.
    Noticed on the way to work today that while pulling a hill under normal throttle, it bogged down like it was going to stall. Revs dropped and it would intermittently go to full boost.
    More throttle didn't seem to help.
  12. #12 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    drive it at night, when its good and dark. drive it rather hard for a bit, then pull over look under the car to see if the cat is glowing red. pop the hood make sure the manifolds are not glowing red too.
    if you see either are hot as hell the cats clogged up for sure.
  13. #13 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    Just left Autozone with new plug wires, electronics cleaner, and some grease.
    While I was there, I got them to pull codes. Here is what they pulled:
    P0341
    P0300
    P0122
    P0366
    I am also uploading a clip of me pulling the hill that gave me trouble this morning. It isn't as bad in the video as it was early this morning.
    I'll post a link when it finally uploads.
  14. #14 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    start with this one. check the wires to the TB for damage. http://www.obd-codes.com/p0122 or the tps could be bad, or the TB is just gummed up bad and needs to be cleaned.
    http://www.obd-codes.com/p0300 your random mis fires corroded coils or the old wires.
    then these 2 both lead to the cam sensor. http://engine-codes.com/p0366.html http://www.obd-codes.com/p0341
  15. #15 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    Car Diagnostic: Exhaust noise, low power, miss?: http://youtu.be/cOwZaGepAdg
    Here's a little clip pulling the hill I had trouble with this morning.
  16. #16 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    sounds like its mis firing all over when you get in the gas.
    start with the codes. they hold the key. new plug wires to start with.
  17. #17 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    Ok. Should I clear the codes after I do b plug wires?
  18. #18 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    you can clear them, see what comes back.
  19. #19 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    OK. Did plugs and wires, but that didn't help any.
    Guess I'll start on P0122 next :/
  20. #20 Re: Engine Miss? (Low power, lots of vibration, "blub blub" noise from exhaust)
    Aug 2011
    Birmingham, AL
    *UPDATE*
    Last night in chat, member RareGMfan sent me to a link to trace down an engine miss.
    First step called for a cylinder check by unplugging each injector to determine which cylinders were affected.
    Cylinders 1, 3, and 5 checked out.
    4 and 6 I couldn't get unplugged on my short lunch break.
    Unplugging number 2 yielded no change in the way the engine was running. This is the same spark plug that had quite a bit of oil on it when I changed it, if that means anything.
    I assume the coil for 2 and 5 is ok since number 5 passed the cylinder check.
    Your thoughts?
    Also, I noticed today that the miss didn't show up until I had been driving a bit and reached operating temperature.
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. Headlight blub question
    By kjohnson in forum Visual/Body Modifications
    Last Post: 08-02-2011, 02:08 AM
  3. "Reduced Engine Power" message
    By TomDaBomb2u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2009, 11:00 PM
