Thread: How to install a transmission cooler??
Results 1 to 20 of 38
  1. #1 How to install a transmission cooler??
    GT Level Member gpbastard's Avatar
    Florida
    01 GP SE 3.1 4t65e transmission. Stock.
    I'm going to be putting in a trans. cooler here pretty soon along with a shift kit (getting the classic hard shifting). I've looked around the site for a how-to but haven't been able to find anything specific to these cars. I plan on putting a Hayden 1403 cooler in. Can someone chime in with a step by step on this. Does the bumper cover come off, do you use the zip ties that come with it etc. Thanks for any advice on this.
    gpbastard
  2. #2 Re: How to install a transmission cooler??
    Indiana
    There are a few how to's that are stickied in the how to section...
  3. #3 Re: How to install a transmission cooler??
    Florida
    Thanks, i think I checked their but I'll go back and double check.
    gpbastard
  4. #4 Re: How to install a transmission cooler??
    Florida
    I looked and all they had was a video of a guy who already did his. Basically how to route the hoses. I'll keep looking through the forums.
    gpbastard
  5. #5 Re: How to install a transmission cooler??
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I don't think a cooler will fix the hard shifting, but like D said few write ups.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: How to install a transmission cooler??
    Florida
    I'm going to put in a Transgo shift kit as well. Most people have had pretty good luck doing it this way (cooler and shift kit).
    gpbastard
  7. #7 Re: How to install a transmission cooler??
    GTP Level Member
    Aug 2012
    st louis park, MN
  8. #8 Re: How to install a transmission cooler??
    Florida
    Thanks for the links especially the grandprix.net one. that was informative. i'm going to spend some time looking over everything. I have a much better idea on how I'mgoing to do it now.
    gpbastard
  9. #9 Re: How to install a transmission cooler??
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by gpbastard View Post
    Page 2 of the last link I provided has a sketch of how I routed my lines (if you didn't get there already).
  10. #10 Re: How to install a transmission cooler??
    Florida
    Quote Originally Posted by stocker View Post
    I'm actually going to bypass the radiator cooler part of it. these links and diagrams really help. Thanks for the links.
    gpbastard
  11. #11 Re: How to install a transmission cooler??
    SWPA
    Stocker, I looked at your sketch and it looks like you have the lines labeled backwards as everything that I have read indicates the return line is on top.
    I want to get my cooler installed finally.
    From what I have read it looks like I basically need to just cut the return line at the rubber, double barb it, run to Hayden cooler, double barb it, run back to return line going to transmission.
    Does that sound right or am I making it too simple? LOL
  12. #12 Re: How to install a transmission cooler??
    Arizona
    Stealthee your 100% correct and yes it is that simple...
  13. #13 Re: How to install a transmission cooler??
    SWPA
    Thank you sir.
    Just put in my online order at Advance to get 4.5 feet more rubber line (just in case), double barbs, and fuel injection hose clamps. Went ahead and got 8 hose clamps because I figure I will double clamp each connection.
    Grand total on that was $15.92 after discount code TRT30.
    The guys at Advance love me, because I am one of their easiest customers to deal with..... that and the fact that I have probably spent $10k there over several years. LMAO
  14. #14 Re: How to install a transmission cooler??
    Apr 2012
    Dayton, OH
    I thought the hose for the cooler would slip over the end of the existing trans line because its basically barbed for the quick connect, or is it the fact using double barbs and hose clamps makes extra sure the line won't pop off?
    2012 F150 STX
  15. #15 Re: How to install a transmission cooler??
    Arizona
    You preferably always want to cut the rubber hose and insert a double barb for the most secure connection. The metal stock line offers nothing for the hose to grab on too.
  16. #16 Re: How to install a transmission cooler??
    Apr 2012
    Dayton, OH
    Ahh gotcha, thought when I do mine I could avoid hacking up one of the lines but I guess if you wanted to go back stock its just simple as putting the 2 stock lines on the barb fitting. Think fuel injection clamp would be better than a hose clamp for the price difference?
    2012 F150 STX
  17. #17 Re: How to install a transmission cooler??
    SWPA
    I wanted to avoid the same, but finally said screw it. Like you said, I could always just double barb the stock line back together, or worst case Advance has the return line for $20.
  18. #18 Re: How to install a transmission cooler??
    Arizona
    Both will work just fine but yea if use fuel injection clamps
  19. #19 Re: How to install a transmission cooler??
    Dec 2012
    troll land
    Make sure that if bypassing the stock cooler you add a fan for it, or do like I did and wire an engine fan to run all the time, otherwise temps could shoot up at long stops and slow speeds
  20. #20 Re: How to install a transmission cooler??
    Aug 2013
    McDonald PA
    Quote Originally Posted by l67ss View Post
    Hmm didn't think of that
  1. *HOW TO* LS4 Transmission Cooler Install
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 08-09-2015, 09:32 PM
  2. Trans cooler install on 07 GT
    By stealthee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2013, 12:21 PM
  3. Desert Fox transmission cooler install.....and FMHE???
    By copgtp in forum General Tech Discussion
    Last Post: 06-25-2011, 09:52 PM
  4. transmission oil cooler
    By 03buickregalls in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 09:11 PM
  5. Going to install a transmission cooler tomorrow, have some questions.
    By ya61x in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2010, 11:49 PM
