Thread: 05 gtp running warm
Results 1 to 6 of 6
pontiacGTP123 05 gtp running warm 06-19-2014, 02:23 PM
QUICKSILVER462 Re: 05 gtp running warm 06-19-2014, 02:36 PM
pontiacGTP123 Re: 05 gtp running warm 06-19-2014, 03:07 PM
nik12937 Re: 05 gtp running warm 06-19-2014, 03:22 PM
pontiacGTP123 Re: 05 gtp running warm 06-19-2014, 03:35 PM
REDCRAPGP Re: 05 gtp running warm 06-19-2014, 05:56 PM
  1. #1 05 gtp running warm
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Well pretty much finished building my wrecked 05 gtp. Started driving it Tuesday, but ever since it's been running a tick mark past 210 idling or going down tr road. So I replaced the thermostat to a 180 and still the same. I have bled the coolant but I get no air. It slowly gets up to a little above 210 when driving but never gets any hotter. Also the car doesn't have lower radiator baffle or deflector.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: 05 gtp running warm
    HUDSON
    If you are judging the actual running temperature of the engine with dash gauge, you should know that the factory gauge can at times be inaccurate. Even so, 210 is not even boiling, if you hold that temp in all conditions, it is good.
  3. #3 Re: 05 gtp running warm
    stanford Ky
    Well I know the plastic plug on the temp sensor is broken. So I'll replace the sensor and see what it reads
    99 gtp- sold
  4. #4 Re: 05 gtp running warm
    Pennsylvania, USA
    Switching to a lower temperature thermostat won't have any effect on running temperature while sitting unless the fans are programmed to come on sooner as well; better off with the stock 195 if it isn't tuned. A 180 only really benefits decently modified engines to lower the KR a bit, but you sacrifice fuel efficiency in exchange for that.
    I believe the stock turn on point for the low speed fan setting is right at 210 degrees, so if that's really your temperature it's completely normal. My gauge will get slightly above the very center line when sitting in traffic, go back down, and back up as the fan cycles on and off. Once moving (giving the radiator continuous air flow), it will drop down between the 1/2 mark and the 1/4 mark on the gauge.
    As a side note, I got my 05 used a few years back, and while lowering the subframe a few months ago I discovered I didn't have the lower radiator baffle at all. Remnants of a front-end collision no doubt. I bought one and installed it for the hell of it, but in terms of temperature I haven't noticed any difference. I'm just a perfectionist when it comes to things like that.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  5. #5 Re: 05 gtp running warm
    stanford Ky
    Yeah mine stays a tick mark above the middle big mark all the time.
    99 gtp- sold
  6. #6 Re: 05 gtp running warm
    Also 180t is rather useless unless your PCM is tuned for it that way you can have the fans come on at 180.
    04 Comp G.
  1. Running Warm - rad fans never go on high?
    By crash2599 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2016, 11:39 AM
  2. Running pig rich and stalls when warm
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2014, 07:16 AM
  3. Running Warm after Coolant flush
    By Lishap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2013, 09:39 AM
  4. Replies: 1
    Last Post: 02-08-2012, 10:09 PM
  5. engine running warm?
    By wiwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2011, 11:00 AM
